Old 07-08-2020, 10:41 AM   #1
Don
Don's Avatar
Default Flywheel on a 21 stud
I only have a FW that uses a 10 inch PP ,will this work on a 37 21 stud engine??
The FW came off a 59ab truck engine,,,,,it fit the 21 stud engine aright ?but was wondering about starter match up and bell housing hitting thanks
DON P
Don is offline   Reply With Quote
Old 07-08-2020, 11:04 AM   #2
cas3
Default Re: Flywheel on a 21 stud
it will work just fine
Old 07-08-2020, 07:06 PM   #3
35fordtn
35fordtn's Avatar
As long as you are not using a 32-34 transmission case it will work just fine.
