03-29-2020, 02:22 AM | #1 |
Mutant B Carb
I purchased (what I thought was) a Model B carburettor, for the purposes of acquiring a core to be re-built. I didn't look close enough, for though it has nearly the form of a Model B carb., it has some clear differences, as shown in the attached pictures. As shown in the first picture, I see
A) Something akin to an oversize secondary well (???) B) An additional flow valve in the main bowl C) An outlet through a different air passage, which connects to an opening on the air-side of the choke plate D) A 'sleeve' for the main jet Also, it does not have the traditional 'GAV' needle valve as found on A and B Carbs. Question: Does anyone know what the carburettor is, and whether anyone sells replacement parts for it? Thanks to all, Andrew |
03-29-2020, 04:36 AM | #2 |
Re: Mutant B Carb
Most likely it is a Zenith Carburetor from a tractor. Tractors usually don’t have the GAV.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
03-29-2020, 09:53 AM | #3 |
Re: Mutant B Carb
Allis Chalmers used these carburetors on their early model WC tractors. They had a slightly smaller venturi and did not have the GAV or high speed enrichment circuits that the Ford B used.
03-29-2020, 11:09 AM | #4 |
Re: Mutant B Carb
Is there a number on the round tag on the bowl cover??
Bob |
03-29-2020, 12:14 PM | #5 |
Re: Mutant B Carb
Looks like it is air balanced for an air cleaner. I have a Model A type Zenith that is like your B carb. It is not for an A or B though.
03-29-2020, 05:08 PM | #6 |
Re: Mutant B Carb
AL in NY |
03-29-2020, 07:26 PM | #7 |
Re: Mutant B Carb
OT; Even the Zenith Model A clone carb used on the Gleaner combine and other equipment had an air balance tube for use with air cleaner, but no GVA.
I know the voices aren't real but damn they have some good ideas! |
