09-05-2019, 09:03 PM | #1 |
split pins usage
Clem with another dumb Q.
Are there places where the split pins are used for other than holding something on? Like thrust support or end of travel pin? Meaning why do split pins need to be so thick? |
09-05-2019, 09:08 PM | #2 |
Re: split pins usage
Some folks call cotter pins "split pins".
Are you referring to a "roll pin"? |
09-05-2019, 09:51 PM | #3 |
no: Cotter pins
09-06-2019, 02:03 AM | #4 | |
Usually there is a washer involved to protect wear and tear. If you are experiencing difficulty removing them from your axle shaft pick up a tool catalog and find a cotter pin puller. It's like an ice pick that got slammed in a door jamb. With the extra pointy end, one can catch the eyelet and leverage the bent b#**#*d right out of its hole. For axles and spindles I always look for the longer ones. Easier to spread open, just cut away what you like. Disclaimer: The best though is not having arthritis. ( Sorry Ryan )
Enjoy yer day. Tom Hate can't fix what it started. |
09-06-2019, 08:48 AM | #5 |
"It's like an ice pick that got slammed in a door jamb."
That's a great description right there. Mart. |
09-06-2019, 09:01 AM | #6 |
09-06-2019, 09:34 AM | #7 |
Keeping the drip hole in the early Ford v-8 oil pan was a good use for a split pin.
https://www.fordbarn.com/forum/attac...5&d=1332214197 |
09-06-2019, 12:35 PM | #8 |
I forgot the drip hole fixer. Thanks
09-07-2019, 08:44 AM | #9 |
What do they call a pli that looks like a nail but with a split down one side that’s under tension when driven into a hole!!!!
DON P |
09-07-2019, 11:57 AM | #10 |
A hard to pull out pin or nail. 8^) Jack E/NJ
09-07-2019, 12:16 PM | #11 |
Spring pin, SOME CALL THEM ROLLED PINS
09-07-2019, 12:22 PM | #12 |
Roll Pin.
09-07-2019, 04:52 PM | #13 |
Ok.....
DON P |
09-07-2019, 10:08 PM | #14 |
