05-14-2019, 09:33 PM | #1 |
34 Tudor roof information
I have a 34 2 door sedan that i am bringing back to life. It is missing all roof wood and brackets. I can buy the wood. Are the metal brackets available? If not, could I just use the long wood and assemble it without the brackets? Not worried about being correct. Thanks
05-16-2019, 07:30 AM | #2 |
Re: 34 Tudor roof information
You should be able to pick them up at Hershey. Stop over my spot RCK14 21 Ill explain. Pete/Ct.
05-16-2019, 11:12 AM | #3 |
Like these ?
How many do you need ? One of my 2- dr's has 3 per side one has 4 My Victoria's have 4 per side. |
07-14-2019, 09:27 PM | #4 |
Bttt
07-14-2019, 09:54 PM | #5 |
there are small brackets at the ends of each wood bow where the bolt goes thru, easy to make, if no one has a pic on file i'll take one tomorrow night after work. the wood bows basically match the contour of the roof shape, so you could make a template of cardboard at the rear, and another at the front. you will find the arch gets flatter as you get to the front. make em too big, and carve it to your eyeball's liken.
07-14-2019, 10:51 PM | #6 |
