Old 12-09-2018, 06:23 AM   #1
Dean Lemoine
Dean Lemoine's Avatar
Default Rear spring lubrication
I've disassembled the rear springs on my '29 to be sandblasted and painted. I'm looking for recommendations on lubricants before being reassembled. Thanks in advance
Dean Lemoine is offline   Reply With Quote
Old 12-09-2018, 07:26 AM   #2
Step-down
Step-down's Avatar
Default Re: Rear spring lubrication
You need to polish all the grove or marks in the surface also polish the ends of each leaf
So it doesn’t dig in the leaf below
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 12-09-2018, 07:44 AM   #3
brokenspoke
NAPA sells "slip plate paint" in a spray can
brokenspoke is offline   Reply With Quote
Old 12-09-2018, 08:23 AM   #4
Terry, NJ
Terry, NJ's Avatar
I don't know if it's bad or good, but heres how I did mine. With the spring out and under no tension, I merely loosened the center bolt so the gap between the leaves grew slightly. Then I poured oil across the side of the leaves and stood it on edge for about a week. Then turn it on the other side and do the same thing. The oil saturates the spring. Then I work grease in between the leaves. Tighten up the center bolt and I'm good to go. Rides good, no squeaks, what more do I want?
Terry
Old 12-09-2018, 09:40 AM   #5
Ray64
Ray64's Avatar
Powdered Graphite mixed with axle grease. Put on with paint brush.
Ray64 is offline   Reply With Quote
Old 12-09-2018, 10:26 AM   #6
katy
katy's Avatar
Slip plate paint works great. Besides NAPA it's also available from your local friendly John Deere dealer.
Old 12-09-2018, 10:40 AM   #7
Y-Blockhead
Y-Blockhead's Avatar
You might consider installing spring covers after you get them all lubed up to keep the grease in and dirt out.
Old 12-09-2018, 11:40 AM   #8
JohnLaVoy
JohnLaVoy's Avatar
We use a product called EZ Slide, it is available at Tractor Supply locations and on line. The picture shows a 1QT can but it comes in spray cans too. We are doing the front spring for the next Model A Times build, a 1929 Cabriolet that will be a great tour car.
JohnLaVoy is offline   Reply With Quote
Old 12-09-2018, 12:06 PM   #9
PC/SR
Powered graphite from the little tubes used for key locks.
PC/SR is offline   Reply With Quote
Old 12-09-2018, 03:02 PM   #10
whirnot
whirnot's Avatar
There are many opinions but I see no need to do anything. Never seen one worn out. Any lubricant such as oil that is exposed will attract dust, and turn it into grinding compound. If it ain't fixed Don't broke it.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 12-09-2018, 04:16 PM   #11
Lawrie
Lawrie's Avatar
grease and graphite powder then wrap the whole assembly with denso tape,
Lawrie
Old 12-09-2018, 04:17 PM   #12
Synchro909
Synchro909's Avatar
After the leaves have been sandblasted like yours, I grind out the ridges and grooves till they won't cause a problem (not completely removed), then mix a handful of graphite in primer and paint them. Then, I reassemble and paint them black. The primer holds the graphite in place and being a dry lubricant, it does not attract dirt and grime. I've been doing that for about 25 years and it works so well, I can't see any reason to change.
Old 12-09-2018, 07:30 PM   #13
Jim M
Jim M's Avatar
I did my rear springs a short time ago. I also ground the bottom of the tapered ends of the leaves so they somewhat looked like a ski. This will prevent them from digging in the the leaf below after they are installed. I painted them black then sprayed them with the graphite sold in spray cans. Came out fantastic and no noise and hopefully will not dig into the leafs below.
Jim M is offline   Reply With Quote
Old 12-10-2018, 08:18 AM   #14
Terry, NJ
Terry, NJ's Avatar
When oiling the leaves, it's important to remember that when tightly bolted and installed, under tension. there is no openings for dirt, sand to enter these joints. They are closed tight.
Terry
Old 12-10-2018, 02:32 PM   #15
jwilliams81
jwilliams81's Avatar
Slip-Plate. Get the brush on kind. Two-Three coats per side.
When it's dried, put it all back together. Then give it the unit a coat of black paint.
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
Old 12-10-2018, 04:15 PM   #16
JOHN CT
JOHN CT's Avatar
I took the springs during the restoration stage. Ground the edges just to remove the groves paint with rust oleum paint. Then I rapped them with this cover. It’s been years and no squeaky
https://www.snydersantiqueauto.com/spring-covers
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 12-11-2018, 10:20 AM   #17
SeaSlugs
SeaSlugs's Avatar
I sandblasted mine, ground out the grooves, painted with 2 coats of por 15, then slathered on my own 50/50 mix of graphite and open gear grease. Then bolted it all together and watched the grease spurt out like playdough. Springs are super smooth (as smooth as AA springs will allow at least)
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 04-11-2019, 02:38 PM   #18
Chris Haynes
Chris Haynes's Avatar
I find Slip Plate Lubricant. But nothing that says paint??
https://www.amazon.com/s?k=slip+plat...ref=nb_sb_noss
1921 Runabout
1930 Tudor
Early 1930 AA
Old 04-11-2019, 03:43 PM   #19
jwilliams81
That's the correct link. Get the quart, brush it on.
Cincinnati, Ohio
Old 04-11-2019, 04:38 PM   #20
Tom Endy
Tom Endy's Avatar
I have restored a number of front and rear Model A springs. My method is to bead blast each leaf, grind the wear grooves down and bevel the sharp edges on the ends. I then sprayed the contact areas of each leaf with slip plate, which is a dry graphite, from John Deere with several heavy coats. It dries very quickly. As the leafs are assembled an excess will squeeze out. I wipe the spring clean with lacquer thinner and spray it with black Rustoleum paint. When installing back on the car I recommend installing the fabric spring covers available from the suppliers.
Tom Endy
