Old 01-19-2018, 09:12 AM   #21
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: 1935 brake rods
My avatar still has mechanical brakes that work well, and will never be converted to hydraulics as long as I own this car.
I own another 35 Ford that has the absolute worse quality and functioning hydraulic conversion that I've ever seen. This was done by a previous owner, and this car will be converted back to stock 35 mechanical brakes.
John
Old 01-19-2018, 09:16 AM   #22
35fordtn
35fordtn's Avatar
David you are correct, sorry for any confusion
Old 01-19-2018, 04:02 PM   #23
Viv W
Hi All,
35Fordtn, many thanks for your generous offer, I will PM you to discuss further.
Many thanks to all the other Barners who have offered advice and their input.
best wishes to you all.
Viv.
Viv W is offline   Reply With Quote
Old 01-19-2018, 09:51 PM   #24
Steve Seidl
Steve Seidl's Avatar
Per the parts manual the part number is 48-2499 and they are 75 inches long for 35-36 passenger and commercial vehicles.
Steve Seidl is offline   Reply With Quote
Old 01-20-2018, 12:50 AM   #25
48-710
35fordtn,
PM sent
48-710 is offline   Reply With Quote
Old 07-12-2018, 04:21 AM   #26
Viv W
Hi All,
Many thanks for the information on the 6 rod braking system. I have now made up the rear brake rods as per the dimensions given to me.
Please may I ask if any of you have information on how to adjust the brakes on this braking system, particularly RHD. All the information I have and can find, relates to adjusting the 4 rod braking system.
Many thanks
regards
Viv.
Old 04-21-2020, 05:38 AM   #27
Withrick
I could use one rear brake rod for a 35 four door
Withrick is offline   Reply With Quote
Old 04-21-2020, 01:15 PM   #28
VeryTangled
VeryTangled's Avatar
Michael at Third Gen Automotive will have it.
His contact info is in the first post of this thread...
https://www.fordbarn.com/forum/showt...ght=1935fordtn
-Jeff H
Old 04-21-2020, 02:11 PM   #29
Brian
Brian's Avatar
Viv, There is a special return spring used that hooks onto the 5/16 dia front clevis pin of the rear brake rods, the other end hooks onto the rear box portion of the centre X member. Do you have that in place?
Old 04-22-2020, 09:55 PM   #30
VeryTangled
One thing about rods is they have to be dead straight AND have circular not egged-out holes in their ends. Same for all pins and clevises that they're going through.
-Jeff H
Old 04-23-2020, 04:19 PM   #31
Viv W
Hi Brian,
I have a return spring hooked up from the brake rod that goes to the pedal, but no others, please can you post a picture of the springs you are talking about.
I haven't driven the car yet, still have to pull the steering column again and replace the worm and sector, but I will get to it.
Thanks for the input.
regards Viv
Old 04-23-2020, 05:01 PM   #32
Brian
Brian's Avatar
The spring I refer to is #48-2472 as pictured in the second page posted in post #2 by Alex
Old 04-24-2020, 02:47 AM   #33
Viv W
Thanks for the pictures Brian, I will look on my freinds 35 coupe and have some made.
I forgot to ask, are these springs on the service brake rods, the emergency brake rods, or both, many thanks
regards
Viv
Old 04-24-2020, 04:20 AM   #34
JM 35 Sedan
Originally Posted by pooch View Post
Are some people still using mechanical brakes on a 35?
I have 2 mint 35 backing plates with shoes/linings ,perfect lever bushes that I cannot even get $ 20 for.
I even advertised them as being great to put a clock in and hang off the garage wall.
I am about to scrap them.
pooch, I'm pretty sure it's bad luck to scrap good Ford parts......
John
Old 04-24-2020, 04:28 AM   #35
Brian
Brian's Avatar
Hooks onto the 5/16 clevis pin between the two rear service brake rods, where they attach to the main cross shaft.
Old 04-24-2020, 05:20 PM   #36
Viv W
Many thanks, will look tomorrow.
Regards
viv.
Old 04-24-2020, 05:32 PM   #37
Viv W
Regards
viv.
