07-31-2019, 09:35 AM | #1 |
Pay attention to the little flashes...
The battery in my '29 Roadster was completely dead the other day. Hooked the charger up for a couple hours and could get it started, but the ammeter showed only a couple charging volts during a checkout run around the block. Noticed a very slight current draw on shutdown, so pulled the fuse.
The next morning I was going to look a little deeper and out of the corner of my eye saw a small flash over by the radiator when I replaced the fuse. Closer inspection revealed that the headlight conduit had moved and was shorting out against the radiator frame. Pulled it back into position and put some tape where it was contacting the radiator and voila, everything was back to normal. Moral of the story - pay attention to the little flashes...
Wayne @ Barb Malvern '19 T Speedster '26 T Touring '29 A Roadster '30 AA Stakebed '30 A Pickup '30 A Town Sedan '31 A Station Wagon '38 Columbia Girls bike (WWII) '40 Elgin Boys bike (WWII) '42 Super Deluxe Tudor '42 Willys MB Jeep '43 Willys MBT Trailer '43 M3A4 Hand Cart '43 Harley Davidson 42WLA with sidecar |
07-31-2019, 10:08 AM | #2 |
Re: Pay attention to the little flashes...
You still have problems as it should not matter if the conduit touches the radiator shell.
Bob |
07-31-2019, 11:23 AM | #3 |
Conduit and radiator are both at ground potential. And there should be no voltage present in that area with the headlights off. Horn conduit has a hot wire in it though, check for frayed insulation there.
07-31-2019, 02:00 PM | #4 |
