Old 06-29-2021, 07:43 AM   #1
Smitty
Smitty's Avatar
Default 50 Ford Overdrive/Driveshaft
I am guessing that I will need a shorter driveshaft for 1950 overdrive transmission than for non overdrive transmission?
Steve
Smitty is offline   Reply With Quote
Old 06-29-2021, 07:56 AM   #2
Frank Miller
Frank Miller's Avatar
Default Re: 50 Ford Overdrive/Driveshaft
They are the same. So is the motor mount, you just need to turn it around.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 06-29-2021, 08:21 AM   #3
Smitty
Smitty's Avatar
Whew, that's good. Tail shaft length is the same just different mount location?
These electric or manual activation? On the dash..or under..?
I am about to convert from regular trans to OD.
Thanks, Steve
Old 06-29-2021, 09:40 AM   #4
Bob C
This is for a Mercury but the controls will be the same.
File Type: jpg Flathead_TransODcontrols_1949to52merc.jpg (46.8 KB, 16 views)
