Old 11-11-2023, 02:17 PM   #1
B-nut
Default 60 hp. V8 Engine weight
Can someone tell us what the 60 h.p. V8 engine weights?
B-nut is offline   Reply With Quote
Old 11-11-2023, 02:37 PM   #2
nelsb01
nelsb01's Avatar
Default Re: 60 hp. V8 Engine weight
In June of 2010, someone responded that Ford listed the weight at 300 lbs. Yet another Google search says a engine ready to fire weighed in at around 220 lbs. (it had a lot of aluminum parts)
All I know is that I transported a bare 60 hp block to Michigan back in 1982, and when I arrived a single person lifted it out of the back of a 1981 Ford Escort station wagon.
nelsb01 is offline   Reply With Quote
Old 11-11-2023, 06:53 PM   #3
B-nut
Thankyou nelsb01.
Old 11-11-2023, 07:46 PM   #4
TJ
TJ's Avatar
The early 60s had tin sides so they would be lighter than the all cast iron ones.
Old 11-11-2023, 07:52 PM   #5
cas3
Wasn't this discussed in Lawson's 60 thread?
Old 11-12-2023, 01:53 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
All I remember was that friggen' fan!
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 11-12-2023, 05:54 PM   #7
tubman
tubman's Avatar
I would imagine there would be a significant difference between a '37 "Tin Side" with aluminum heads and a '40 (being all cast iron).
Old 11-12-2023, 08:33 PM   #8
V8COOPMAN
V8COOPMAN's Avatar
A picture of a V8-60 "Tin Side".
Coop
T5 W/TORQUE TUBE
Old 11-12-2023, 08:50 PM   #9
Lawson Cox
Lawson Cox's Avatar
Coop
Locating the correct fan was a HASSEL FOR SURE, and cost a "right smart",but never let be said that I start out on a vast project with "half vast" intentions.
Old 11-13-2023, 06:26 PM   #10
mcflash
Are you talking bare block?
mcflash is offline   Reply With Quote
Old 11-13-2023, 07:33 PM   #11
Kurt in NJ
Kurt in NJ's Avatar
With transmission—
Model 73, 411 pounds. Commercial
Model 74, 391 pounds, passenger car
Model 75, 454 pounds, big truck
From 1936 service bulletin, 1937 introduction
Old 11-13-2023, 08:21 PM   #12
Tim Ayers
Originally Posted by Kurt in NJ View Post
With transmission—
I know nothing about the V8 60's and what they came in, but I have to ask: Ford offered this wheezer in a big truck (Model 75)? Couldn't have been a big seller.
Old 11-13-2023, 08:42 PM   #13
Lawson Cox
Lawson Cox's Avatar
The 60HP I donated to the Archives Museum had the rare "commercial" transmissioin attached. Probably would not pull out the proverbial
"greasy string" either. Just sayin'.
Old 11-13-2023, 08:53 PM   #14
Kurt in NJ
Kurt in NJ's Avatar
I drove a 60 for a while, to get the best fuel mileage had to keep it under 60, downshift to second as soon as it slowed to 40 on upgrades, over 60 the fuel mileage would go below 30 mpg, 26 mpg at 65-70, flat out it would go 74
The big truck probably spent a lot of time in lower gears
