Old 01-07-2022, 07:06 PM   #1
1934clint
Default 1957 Ford Fairlane 500 heater core
I got a 1957 Ford Fairlane 500 needs a heater core. I am having trouble finding one. Does anyone know where I might find one?
1934clint is offline   Reply With Quote
Old 01-07-2022, 09:16 PM   #2
paul2748
paul2748's Avatar
Default Re: 1957 Ford Fairlane 500 heater core
Here is a list of places to look. It may even be the same as a 57 Bird which is available. Also check with a local radiator shop - you never know.
C & G Ford Parts
Green Sales
Early Ford V8 Sales
Gotham Auto Parts.
Dennis Carpenter
Concourse Parts
Tee-Bird Products
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 01-08-2022, 05:42 AM   #3
KULTULZ
KULTULZ's Avatar
Exclamation Re: 1957 Ford Fairlane 500 heater core
Go Here -
https://concoursparts.com/
- SEARCH -
I would think it would be a quality part seeing as how proud of it they are.
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
KULTULZ is offline   Reply With Quote
Old 01-08-2022, 06:31 AM   #4
1934clint
Thanks for the information it will help me out.
Old 01-08-2022, 09:03 AM   #5
51504bat
51504bat's Avatar
When I needed a heater core for my '54 I could get a pepop from Concours for around $110.00 plus shipping or have the local shop recore it for $150.00 I decided to go with the recore. Try to keep the local guys in business. But I've always had good luck with Concours so I'm sure the one they have will be fine.
Old 01-08-2022, 08:31 PM   #6
Alaska Jim
Alaska Jim's Avatar
If you have a good radiator shop near you , take them your old one and have them check and see if they can put your old tanks on a new core. I did this for my '51 Merc. I think it cost me about a hundred bucks back about 15 years ago
Alaska Jim is offline   Reply With Quote
Old 01-09-2022, 01:38 PM   #7
1930artdeco
1930artdeco's Avatar
I just had mine recored as it had a hole in it. They just kept the sides and soldered the valve on in the open position. This taking out a potential leak point. I have had other people tell me an early mustang core will work.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 01-10-2022, 06:19 PM   #8
Gene F
Gene F's Avatar
Walk in to your local NAPA store. They typically can get you one in a day or two.
