12-27-2010, 08:24 AM | #1 |
Replacing the top on a Vicky leatherback
I have a 1931 Leatherback Vicky that will need to have the top replaced as part of the restoration.
I read an article that was published in the Victoria association newsletter years ago, where someone recommended replacing the chicken wire with a full sheet of sheetmetal. The purpose was to keep the wind from blowing the fabric top up like a baloon when going down the road with the windows open. Has anyone replaced the chicken wire with sheetmetal and then put the top material over it, Coupe, sedan etc. and any drawbacks? Thanks Jim |
12-27-2010, 09:43 AM | #2 |
Re: Replacing the top on a Vicky leatherback
On my '28 Leatherback used 1/8" baltic birch instead of the chicken wire. Made the covering to just fit within the area where the chicken wire went. Had to splice two sheets togather to get the full length. Used 1/2" #4 flat head screws that I countersunk the heads into the plywood placing the holes about every 2"s. Was able to insulate the underside then for sound and comfort. Coated the topside of the plywood with 3 coats of Marine Varnish to make waterproof before putting on the top material.
12-27-2010, 09:48 AM | #3 |
JR,
Thanks for the reply. Jim |
12-28-2010, 01:07 AM | #4 | |
12-28-2010, 07:41 AM | #5 |
I was behind someone towing the Vicky but never did it blow up like a balloon |
