Old 01-27-2022, 10:13 AM   #1
william bacon
Default Looking for measurements on 32 sedan
Looking for the measurement between the screw holes at the a pillar that hold the sill plate. That's side to side. Does anyone know of a book with body measurements for the 32 sedan. Thanks
william bacon is offline   Reply With Quote
Old 01-27-2022, 11:42 AM   #2
Mart
Mart's Avatar
Default Re: Looking for measurements on 32 sedan
Hard to judge exactly what measurements you want, but here is a photo of the sill plate on my 32. You can see the screws. The second pic shows a horizontal screw near the front.
Mart.
Old 01-27-2022, 12:01 PM   #3
william bacon
I was looking from that front screw in the scuff plate to the same place on the other side of the car thanks
Old 01-27-2022, 12:18 PM   #4
Mart
Mart's Avatar
The horizontal one arrowed or the frontmost of the vertical screws?
Vertical screws: 38 to 38-1/16" It's a little hard to measure single handed as the seats are a slightly in the way.
Rough measurement across the scuff plates at the front of the door opening is 36-5/8"
Old 01-27-2022, 12:32 PM   #5
william bacon
thanks
Old 01-29-2022, 10:48 AM   #6
william bacon
Those numbers you gave me were good on mine. I have changed the rocker and it doesn't seem to stick out far enough under the door.
I was wondering if you could measure the flat part of the rocker right at the A pillar. Right were the door sits over it. thanks
