11-23-2017, 04:36 PM | #1 |
motorcraft oil
Any of you guys running Motorcraft oil in a fresh mostly stock 8ba ? What vis. ?
I'm think'n 10 w 30 conventional with 180 stats. Thanks in advance ! I find myself reading about stuf that doesn't pertain 2 anything i'm doing cause you guys make good reading. Flatheads 4 ever.......... mike |
11-23-2017, 05:09 PM | #2 |
Re: motorcraft oil
I mostly use M/C Synblend 5w/20 in my stock early 38 21-studder. Sometimes I use other brands 5w/20. Jack E/NJ
11-23-2017, 06:10 PM | #3 |
Re: motorcraft oil
Motorcraft 10W 30 Diesel in a stock 59AB 1948 Ford.
11-23-2017, 06:18 PM | #4 |
Re: motorcraft oil
That will be fine. I think that these days some people get overly concerned about oil because a few people had trouble with flat cams on hi-performance engines that probably had more to do with assembly problems than zinc levels. All commercially available oil has to meet a set of standards that are more than adequate for a flathead Ford (non-detergent oils excepted). I do, however, commend you on opting for 180 thermostats. A lot of people run their engines too cold. The quest for the highest reading on the oil pressure gauge and the lowest on the temperature gauge is not a good trend.
11-24-2017, 07:08 AM | #5 |
Re: motorcraft oil
Thanks fellas, and i agree with you Tubman. My tired engine runs @ 180 unless it is cool outside,even if i git on it some it never overheats in hot weather. Thanks again. m
11-24-2017, 08:22 AM | #6 |
Re: motorcraft oil
11-24-2017, 09:15 AM | #7 |
Re: motorcraft oil
I'm glad to see there are allot of smart people out here. Keep in mind that the stock Flathead has only 40 lbs of spring pressure and almost the same amt of bearing surface as a SBC
11-24-2017, 04:35 PM | #8 |
Re: motorcraft oil
Motorcraft Syn. Blend 5W-30 used here. Buy it by the 5 qt. jug at WalMart, not that expensive.
Been using it quite some time no problems. 59AB flathead. |
11-24-2017, 04:47 PM | #9 |
Re: motorcraft oil
Cam "flatting" is very rare in a stock Ford flathead, as OR above says. We do find it frequently in newer vehicles, due mostly to failure of the owner to change oil and filter according to the owner's manual. In any case, today's oils are light years ahead of the oils available when these older vehicles were made, and any good brand should be adequaite
without zinc or other additives. I've run Castrol 20W-50 for years without problems. |
11-24-2017, 05:20 PM | #10 |
Re: motorcraft oil
I was a fleet mechanic for 30-years. We were only allowed to use Delo 15W40 because we bought it in bulk form pumped into a 400 gallon underground tank. No matter what the under hood label recommended the engine got Delo 15W40 diesel oil. Small four-cylinders, generators on up to large diesels. I never saw a camshaft go flat. We never had any wear issues unless the oil all leaked out. We probably had a thousand vehicles and I don't remember an engine ever wearing out. They usually seized up Drivers were suppose to check the oil and we only serviced them every 6-months so you can imagine what happened. Sometimes those engines would go 12K miles between services. The vehicles always fell apart long before the engines gave-up. So that convinced me to use that oil in all my older cars. It has all the anti-wear additives you need for your flat tappet cams because the additives need to be their for the pressures placed on those diesel engines wear surfaces. The viscosity is great for cold start ups and warm driving. The modern engines that use "0W" and"5W" viscosity have really tight clearances in their engines. I don't know think I would feel comfortable using it in an older engine. Most of us stick with what we know has always worked until the government takes it away. And the other guy that mentioned Walmart is correct. You can buy 5-gallon jugs of Delo 15W40 cheaper there than any other place on the planet. In fact I had a neighbor that owned a oil change shop and he bought all his oil from Walmart.
11-24-2017, 09:36 PM | #11 | |
Re: motorcraft oil
11-24-2017, 06:17 PM | #12 |
Re: motorcraft oil
The API service classification tells a person about everything about the motor oil additives in a given package. This link is for standard auto motor oil but there are other ratings for diesel trucks. http://www.pqiamerica.com/apiserviceclass.htm The brand doesn't really matter due to this. They all have to meet or exceed standards.
SAE 10W/30 viscosity index falls right in the original viscosity rating for the old flatheads and is a decent all weather product. If a person is in a higher temperature location straight grade oils or slightly higher index will give longer service but if the engine has little or no small particle oil filtration then that makes the time limitation for oil change intervals lower anyway so a polymer based oil would be more practical just on the standpoint of availability. |
11-24-2017, 08:02 PM | #13 |
Re: motorcraft oil
rotowrench, you remind me that i grew up on Ford Tri Motors. I Love radial engines and flew right seat in a Ford @ the age of 10 going to Put-in-Bay on Lake Erie. Thanks for your input and thanks to everyone for their info. Have a GR8 weekend ! mike
