Old 09-26-2016, 08:48 PM   #1
tracktguy
Default Tips on replacing 46 convert door glass
Anybody have some pointers on getting the door glass out of the stainless frame without the ss frame? Took it to the local glass shop and he was a bit stumped. The rubber gasket is a real bugger. Also the installation of the new glass with the OEM type rubber gasket will be next. Any info would be appreciated.
tracktguy is offline   Reply With Quote
Old 09-27-2016, 05:16 AM   #2
Mac VP
Mac VP's Avatar
Default Re: Tips on replacing 46 convert door glass
This is from our website section on window glass replacement. It doesn't seem to qualify the convert vs the sedan doors. Hopefully it can help. You have to click through to the succeeding pages.
http://www.vanpeltsales.com/FH_web/f...-40-46_pg5.htm
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 09-27-2016, 06:20 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
Last one I did many years ago involved using a wooden block to tap off the channel after soaking the setting tape with kerosene.
The channel may possibly move without the need of kerosene.
Old 09-27-2016, 09:26 AM   #4
325w
Oak block laid flat on the glass. Hit the block with a rubber mallet. You can also run a blade are thin putty knife around the setting tape. When you put it back together use glass setting tape. It holds the glass better than rubber.
325w is offline   Reply With Quote
Old 09-27-2016, 12:43 PM   #5
tracktguy
Thanks for all your input. Definitely a big help.
