02-01-2016, 11:26 PM | #1 |
Cragar/Winfield Intake
I picked up a neat old intake this weekend for a Banger. I thought I could use it and was stoked on it. But I have another one and this one has giant ports on it. So I wanted to ask if anybody knew exactly what it might have been for. I have a hunch but you know where that leads. So Banger experts what is this?
02-01-2016, 11:30 PM | #2 |
Re: Cragar/Winfield Intake
Ohv ??
02-02-2016, 11:31 AM | #3 |
I would expect that the one with the smaller ports will fit on a stock Model A, while the one with larger ports was cast for a Cragar (Miller/ Schofield) head. The carb flange is for a Winfield and the manifolds are intended to be used in a downdraft application.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery. |
02-02-2016, 11:53 AM | #4 |
Fordor is right but it can be used for either up or down-draft. The one pictured has been used as updraft, as evidenced by corrosion on the front, from a leaky water pump. There may be a small letter-stamp opposite the carb flange indicating size of Winfield carb it is made for.
02-02-2016, 02:16 PM | #5 |
Hey Tim,
Great information from what can be seen ! Can you measure and give center to center of mounting holes , as this will indicate which Winfield size carb that this single 'rams horn' intake was intended for ? That measurement may also confirm why huge intake ports. I also have a question of you concerning the condition of this intake. Can that type of metal damage be repaired back to as made ? I ask, as I know nothing of metal work, but have an original Schofield side plate (valve chamber) cover. It has a corner knocked of (clean break) and since it is original/rare..hesitate to scrape it ? |
02-02-2016, 05:04 PM | #6 | |
A good welder can fill in the pits and you can file and sand it back smooth. If you have a Vo-Tech school near by, they might even do it for the cost of materials. |
02-02-2016, 07:24 PM | #7 | |
Some good information ! I do have such a Vo-Tech school nearby . Just might look into that , thanks . Relative to your wonder stick comment, that reminds me of the current TV ad. It shows someone putting clear liquid onto anything/everything. A special light (ultra-violate ?) is then focused on the liquid between the parts. Voila, fixed in 3 seconds... You seen that yet ? Seems too good to be true |
02-02-2016, 07:29 PM | #8 |
Yes, I've seen that and wondered about it, and just last night my neighbor asked me about it.
Too good to be true usually is. |
02-02-2016, 09:18 PM | #9 |
It's an epoxy that is cured instantly when exposed to strong ultraviolet light. I can't say how good the stuff on tv would be, but we use the industrial version at my workplace and it works very well.
02-03-2016, 11:26 AM | #10 |
In the past, it was "tough", without modern SEALANTS, ADHESIVES, & THREAD LOCKERS! First heard of Loctite when I was working on Jaguars. We mis-read the label & called it, LOKITE. (dum-dee-dum-dum)---We used it to stop the clicking, where the rear axle fits into the wheel hub. POP-RIVETS appeared about the same time, along with Silicone Rubber. YES, I'm OLD AS DIRT! (80)
Old Bill Dad
02-03-2016, 11:40 PM | #11 | |
Interesting ! Always looking for GOOD stuff for emer repairs on Model A ! Does your industrial version make strong repairs (temporary ?) in stressed parts usage ? Is your industrial version, available for hobbyist/public use? And, can it be undone once applied ? |
02-04-2016, 01:15 PM | #12 | |
02-04-2016, 04:19 PM | #13 |
