Old 09-11-2012, 09:06 AM   #21
socalplanedoc
socalplanedoc's Avatar
Default Re: Towing A Model A
Originally Posted by CarlG View Post
Be aware -- U-Haul has restrictions on the tow vehicle....
Originally Posted by RichardW View Post
12 years ago when I bought my A I rented a trailer from U-Haul and they wouldn't let me pull it with my car....
You can easily see if you're vehicle is a suitable tow vehicle using the U-Haul web site, they even have the entire Model A line available as "towed vehicle" choices!!
http://www.uhaul.com/Reservations/Eq....aspx?model=AT
socalplanedoc is offline   Reply With Quote
Old 09-11-2012, 12:40 PM   #22
1931 flamingo
1931 flamingo's Avatar
I would be wary about towing with the jeep's short wheelbase (unless it's the larger wagon. Short wheel base (even an older K5 type blazer) can lead to sway problems and have seen them roll over. JMO
Paul in CT
Old 09-11-2012, 06:14 PM   #23
mccsix
mccsix's Avatar
A lot depends on what Jeep you're using. My 07 Commander 4x4 is rated to tow 6,500#.
The Jeep weighs 4,800#.
Gene
USN
mccsix is offline   Reply With Quote
Old 09-11-2012, 09:00 PM   #24
Tom Wesenberg
Tom Wesenberg's Avatar
Because the hitch is close to the rear axle on a Jeep (or my 1971 Scoout) I'd consider it a very good tow vehicle. That's the big advantage of a 5th wheel trailer, having the hitch right over the rear axle.
Old 09-11-2012, 09:41 PM   #25
Drive Shaft Dave
I flat towed a Model A chassis with a home made tow bar , from Minneapolis MN. to St. Cloud MN. Had no problems, but that was only 75 M.
Drive Shaft Dave is offline   Reply With Quote
Old 09-11-2012, 11:23 PM   #26
J Franklin
J Franklin's Avatar
Drive it! Thousands have been driven all over this country.
Old 09-12-2012, 12:43 AM   #27
Pete
Pete's Avatar
I have towed model A's and 32's on the ground all over the country.
The tow bars attached to the frame horns with the spreader bar left in.
Building tow bars was a very good sideline business for us in the 50's.
Old 09-12-2012, 10:51 AM   #28
H. L. Chauvin
Not knowing the condition of the vehicle, why not make some sandwiches & ice tea for the trip, drive the A to AZ & return by Greyhound?
That would appear to be a 1930's vintage common sense thought, if this is possible.
H. L. Chauvin is offline   Reply With Quote
Old 09-20-2012, 09:03 PM   #29
1roger41
Drive it ,the secret to life is enjoying the passing of time.
1roger41 is offline   Reply With Quote
Old 09-20-2012, 11:49 PM   #30
Tom Foster
Originally Posted by Frank Miller View Post
One guy a few years back towed with the drive wheels on the ground and forgot to take it out of gear. Put a rod through the block.
I must have the rod in question! It has a nice double-S bend in it. Found it in an engine builder's scrap pile.
Fearless
Tom Foster is offline   Reply With Quote
Old 09-21-2012, 04:03 AM   #31
trulyvintage
trulyvintage's Avatar
Lightbulb Re: Towing A Model A
Originally Posted by graeagle1 View Post
I am planning to tow my Model A from Northern CA to Phoenix AZ using a tow dolly. My question is, would it be better to tow it backwards with the steering wheel secured so the drive trainis not in motiion? I have heard that with the drive shaft moving the output shaft of the transmission could go without lubrication since the cluster gear is not turning. ny suggestions.
Using a tow dolly on a 1000 mile plus trip ?
Show your Model A some respect ....
Potential damage to the Model A because you
more than likely will be towing it at speeds higher
than it was intended to drive ....
Potential damage to the Model A because your
tow dolly fails ....
Get your hands on a trailer and trailer it
Jim
trulyvintage is offline   Reply With Quote
Old 09-21-2012, 05:45 AM   #32
theHIGHLANDER
Tow barred a Model A coupe from Branford, CT to Detroit. When my uncle drove he went too fast, Dad kept cussing him out telling him to take it easy (I was like 16 at the time). We towed it with a 72 Buick Estate wagon. Big F'n car with a 455 and my uncle was cruisin up to and over 80 for a couple dozen miles. Once we got off for fuel or whatever, I could hear something funny. It was a front wheel bearing and we caught it all in time and did a midnight fix at a truck stop. Dad drove the rest of the way, never topping 70MPH (the speed limit back then). No other issues...
theHIGHLANDER is offline   Reply With Quote
Old 09-21-2012, 09:14 AM   #33
TampaTech
A related question... I am about to tow an A from Michigan to Florida on a trailer. Do you suppose it would be better with a fitted car cover on it or off? I'd like to prevent bugs and stone chips but am concerned that the cover flapping might harm the finish. Thanks.
TampaTech is offline   Reply With Quote
Old 09-21-2012, 09:47 AM   #34
mccsix
mccsix's Avatar
Absolutely do not put a car cover on it it will rub down to the metal. Make sur your tow vehicle has a large full width low hanging deflector and you might check into the towed vehicle shields that lay flat in front around the tow bar area.
Gene
USN
Old 09-21-2012, 10:02 AM   #35
TampaTech
Thanks for the info Gene. I will be renting a truck and trailer so we'll have to see how it comes. Maybe they offer to rent shields or deflectors as an option.
Old 09-21-2012, 10:06 AM   #36
Jordan
Jordan's Avatar
I've seen people who have saran wrapped their cars for towing.... and it's always a good prank at a tour.
Cowtown A's
Jordan is offline   Reply With Quote
Old 09-21-2012, 12:46 PM   #37
green30coupe
green30coupe's Avatar
Love bugs are out in Florida right now. They will etch your paint-job if left on too long. I have an enclosed trailer, but I spray the front of my truck and the trailer with PAM cooking spray. DO NOT spray it on your tow vehicle's windshield. I use GLASS PLUS and a squeegee/scrubber to remove the bugs from the windshield at fuel stops. It dissolves the bugs. The PAM & bugs will wash off easily when you get where you're going. Stone chips are another problem... full-width mud flap on the tow vehicle maybe?
Ed
green30coupe is offline   Reply With Quote
Old 09-21-2012, 02:01 PM   #38
MrTube
MrTube's Avatar
I'm a bit scared with people saying they towed, or want to tow a 5000lb trailer (combined load) with an Astrovan or a Ford explorer.
Correct me if I'm wrong, but I wouldn't think an Explorer should tow more than maybe 3500lbs and I would assume far less for an Astrovan.
MrTube is offline   Reply With Quote
Old 09-21-2012, 02:18 PM   #39
CarlG
CarlG's Avatar
U-Haul won't rent you anything that you intend on pulling with an Explorer. Astrovan, no problem. Go figure!
Old 09-21-2012, 02:20 PM   #40
MrTube
MrTube's Avatar
Weird
