Old 02-27-2021, 02:45 PM   #21
tubman
tubman's Avatar
Default Re: Introduction
Late Mercury heads are a poor choice for performance purposes, as they have larger chambers to allow them to have the same compression ratio as contemporary Fords that had a shorter stroke. I think someone has already mentioned EAB heads.
Old 02-27-2021, 03:53 PM   #22
miniceptor86
miniceptor86's Avatar
I was Pikes Peak, as the Ranger anyway. There and Yellow River Forest. Retired in ‘03. Live just a couple miles south of the park now.
Cheers,
Jim&Sandy
McGregor, IA
miniceptor86 is offline   Reply With Quote
Old 02-27-2021, 04:04 PM   #23
Mart
Mart's Avatar
Hello Jim welcome to the Barn.
Lots of good folks here.
Mart.
Old 02-27-2021, 04:51 PM   #24
fortyfords
fortyfords's Avatar
Welcome Jim, these are some really great guys on here and I like old Fords and motorcycles too.
fortyfords is offline   Reply With Quote
Old 02-27-2021, 10:33 PM   #25
53Customline
53Customline's Avatar
Welcome to the Barn. Lots of information here.
Nice truck
53Customline is offline   Reply With Quote
Old 02-28-2021, 06:51 AM   #26
1934
1934's Avatar
Welcome Jim, really like your car!
1934 is offline   Reply With Quote
Old 02-28-2021, 07:19 AM   #27
miniceptor86
Thanks for the info. I was told by the po that it was a ‘53 Merc so I assume it’s 255cid, but haven’t confirmed the 4” stroke. If it is 255 cid would the EAB heads still be preferred?
Cheers,
Jim&Sandy
McGregor, IA
Old 02-28-2021, 07:27 AM   #28
prsvf1
Location: Northern Minnesota - The Cancun of the North!
Welcome, Jim - nice car!
What kind of rear swaybar & shock setup did you use? Could you post some pictures if you have any, I have a 1941 basket case pickup under construction & I want to address that issue.
prsvf1 is offline   Reply With Quote
Old 02-28-2021, 07:53 AM   #29
TomT/Williamsburg
TomT/Williamsburg's Avatar
Welcome , Jim and nice car!
TomT/Williamsburg is offline   Reply With Quote
Old 02-28-2021, 08:16 AM   #30
miniceptor86
it was HR-18000-K from Bob Drake. It required a little trimming of the cross member for the shocks and doesn’t leave much room for exhaust. I haven’t got that part figured out, I cut the pipes off just before the axle and that’s were it stands now.
Cheers,
Jim&Sandy
McGregor, IA
Old 02-28-2021, 08:24 AM   #31
miniceptor86
Thanks!
Cheers,
Jim&Sandy
McGregor, IA
Old 02-28-2021, 10:02 AM   #32
miniceptor86
[IMG][/IMG]
https//www.fordbarn.com/forum/picture.php?albumid=5387&pictureid
Cheers,
Jim&Sandy
McGregor, IA
Last edited by miniceptor86; 02-28-2021 at 10:08 AM. Reason: Delete photo didn’t load
Old 02-28-2021, 10:04 AM   #33
miniceptor86
Cheers,
Jim&Sandy
McGregor, IA
Old 02-28-2021, 10:11 AM   #34
miniceptor86
I added some more photos to my album
Cheers,
Jim&Sandy
McGregor, IA
Old 02-28-2021, 10:13 AM   #35
miniceptor86
I have added a few more photos to my album. I’m not having much luck posting them.
Cheers,
Jim&Sandy
McGregor, IA
Old 02-28-2021, 12:39 PM   #36
tubman
tubman's Avatar
These engines can always use a little more compression. If it was a '53 Merc, it originally had 7.2:1 compression and the EAB's would probably push that close to 8:1. Increasing compression adds to both performance and economy, so it is a "win-win" situation. As you become more acquainted with this site, you can find out there are modifications that can be made to the cylinder heads (both stock and aftermarket) to increase the efficiency of these engines with little cost.
If the engine has not been repainted (and even if it has), traces of bluish-green paint is a good indication of a Mercury engine. Also, see if it has a 3 bolt or 4 bolt carburetor (the Mercury's had 4 bolt carbs).
Old 02-28-2021, 12:47 PM   #37
47Monarch
47Monarch's Avatar
Welcome Jim just to let you know there are some people here that will try and get you interested in all kinds of things again Welcome and be careful
47Monarch is offline   Reply With Quote
Old 02-28-2021, 01:02 PM   #38
miniceptor86
I do a good job of getting myself interested in all kinds of things!
Cheers,
Jim&Sandy
McGregor, IA
Old 03-10-2021, 11:12 AM   #39
Gnater
Hi Jim!
Gnater is offline   Reply With Quote
Old 03-11-2021, 07:34 AM   #40
dan35
Welcome!
dan35 is offline   Reply With Quote
