02-28-2017, 04:26 PM | #21 |
Re: banjo toqure tube
Find a long piece of schedule 40 PVC and some caps to ship it.
02-28-2017, 08:12 PM | #22 |
I hate not being able to edit a post after its been up for ~ 24 hours!! Post #18 should have read...."I believe I have a good one in my stash, but shipping would probably be expensive".
John, I will check the condition of the one I have tomorrow and let you know...probably by sending you a PM.
02-28-2017, 08:50 PM | #23 |
I have a one with very minor pitting. If interested I would take a couple of pictures. I'm in Minnesota so I could ship speeDee. They are cheaper than UPS. It came from a '48 and it has the coupler on it also. Gene
03-01-2017, 11:59 AM | #24 |
Here is a couple of pictures of the one I have to sell if you are interested. Couple that connects to pinion is also on it.
03-02-2017, 12:00 PM | #25 |
trackguy i am interest,it does look much cleaner then mine,do you have a picture of the shaft at the center bearing area that you can send? thanks
03-02-2017, 02:51 PM | #26 |
03-03-2017, 11:35 PM | #27 |
Here are some pics of the one I have alongside a '38-'41 ds that's ~ 2" shorter than a '42-'48 ds. This '42-'48 driveshaft has good splines on the U joint end, no wear in the center bearing area, and some wear on the pinion end splines.
