01-04-2021, 07:44 PM | #21 |
Re: Black single stage paint.
Painted my Zephyr with PPG Concept single stage. Very pricey.
01-04-2021, 07:54 PM | #22 |
Ken, the finish on your Zephyr is amazing, it looks like a mirror in this photo. That is a beautiful, unusual car.
01-04-2021, 08:59 PM | #23 |
It's been mentioned before above, but there are two black tones when painting a car. Brown black and a blue black. The blue black is deeper. Next time we have shows and your walking around, step back on a black car and let the sun reflect off the car. It's easier to see the difference and there is a difference.
On my truck i did single stage ppg 9300 black (it's just standard black for ppg). It's been 6 yrs so the numbers could have changed. It's a blue black and consistent in sunlight. Added a little flattener so it was only a little bit glossy. About 900$ a gallon for color back then. But if I'm going through all the trouble of metal, prep, and sanding. Why would I cut a corner on the final presentable stage. |
01-05-2021, 10:44 AM | #24 |
Thank you for all the information and pictures regarding paints and what to look for, I really appreciate it. If I can get my car to look half as good as the pictures you folks have sent, I'll be happy. Frank.
01-05-2021, 03:15 PM | #25 |
01-05-2021, 03:33 PM | #26 |
01-05-2021, 04:08 PM | #27 |
The single most important parts of the job are the prep work and quality of materials.
Are you planning to strip the paint off of the car before you apply new paint? I hope so - especially if there are any issues with cracking, lifting, bubbling, etc.. If you try to apply new paint (especially lacquer) over older paint - you can easily have adhesion problems - due to the solvent penetrating down into the old material. If you have any doubts, strip the car, redo any sketchy body work, use quality epoxy primers for sealing, etc.. There are many different brands/types of paint that you can use - and some are a lot harder to apply than others (depending on your skills). Do you have experience painting any type of automotive paint -- lacquer, enamel, acrylic enamel, urethane, etc? Do you have a decent quality HVLP paint gun? If not, I recommend the DevilBliss StartingLine or FinishLine guns . . . both spray remarkably well for the price. I tend to use these guns for a lot of my smaller work - versus the high-end SATA stuff I have. You'll find that removing the doors and painting them "flat" will give you the best possible results (if ur not a professional painter). I usually recommend painting the door jambs of the body and the doors - always looks better. I paint the jambs on the doors first, then mask them off before I do the outside areas. BUT, this requires all rubber stripping be removed, a lot of extra prep, masking, etc.. If you are new to painting, consider doing some test work on an old fender (something you can get at a junkyard). Do all the prep, do the primer, do the sealer and then apply the paint. If the paint is going to be rubbed out, then do this as well. Take time to learn on something you're not in love with . . . before you paint your car. Enough outta me! B&S |
01-07-2021, 04:44 PM | #28 |
Thank you Bored & Stroked for your questions and comments. I have no experience with these new paints. I have painted my Model A using bonnie Gray nitrocellular lacquer color on body with acrylic enamel black on the fenders. I painted my brothers old chevy. nova with maroon acrylic lacquer. Both cars came out very well. Back then I was using a devilBliss siphon type gun. I plan on getting a new HVLP gun and I do have a decent compressor. Yes, I do plan to strip off all the old paint and use a good primer. Do I also have to use a primer sealer since I will be at bare metal, just trying to save a step. Thank You. Frank
01-07-2021, 06:00 PM | #29 |
I have had very good luck with Nasson SS black. It is very black.
Nasson was Dupont brand. Last edited by old31; 01-07-2021 at 06:12 PM. |
01-07-2021, 06:14 PM | #30 |
01-07-2021, 07:51 PM | #31 | |
These newer primers seal extremely well and will not let any moisture get through to the metal or body filler below. Once you apply a couple of good coats of epoxy primer, then you can scuff it and put a higher-build type of primer on it (for block sanding and getting all the small imperfections out). If you are stripping and doing bodywork on a section of the car at a time (like most of us do) - then cover each section with the epoxy primer in stages - trying to seal things up as soon as you can. Many shops today only put body filler over the epoxy primer - as it seals the metal off and ensures that no moisture gets through. Depending on the top-coat material (type/brand) and associated recommendations, you may need a 'sealer' over the high-build primer. In many cases a sealer gives you a consistent cover coat - before you apply your base color. Usually sealers are applied right before the base coats - with appropriate flash time (again, depending on the paint). You may be able to skip the sealer step - depending on the materials you use (type and brand of paint), how well your base primer has covered and what is recommended by the mfgr. Best of luck! |
01-07-2021, 08:29 PM | #32 |
I love Centari. My first paint job with a small 2hp compressor using a gun metal gray metallic turned out incredible. One tiny run but a razor blade took care of that. A light polishing, which wasn't recommended and the car looked great. My nephew who is a boy man asked me who/where I got it painted...he sure was surprised.
Just finished using PPG shop line and wasn't impressed. I've seen a lot of cars done with Delfleet and they all looked great in single stage. And the paint chips for selection are about 2"x3" and there are a LOT of them so I'm sure you could find something. Up here Delfleet all in price is about $275 CDN so very reasonable. |
01-07-2021, 08:58 PM | #33 | |
I do regret not wearing a mask. I had red snots for about a week. |
01-07-2021, 09:09 PM | #34 | |
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
01-09-2021, 10:18 AM | #35 |
I am not a paint expert at all. My 1956 Chevrolet (I also have a 52 Ford and a Dodge power wagon) was painted single stage Black and Ivoryt 2 tone and the painter used PPG/Omni 9700. I like the more "dull" appearance of the single stage for original looking cars. It's been 10 years and the paint looks great.
