Old 11-11-2020, 02:16 PM   #1
shew01
shew01's Avatar
Default Radiator Paint
I replaced my radiator a while back because it had a leak in its upper neck, and I couldn’t find anyone to repair it. All the radiator shops I contacted near me only replace radiators nowadays.
I finally found a radiator shop about an hour away what still repairs radiators, and I got it repaired today. However, the guy didn’t want to mess with painting it.
Would this paint be suitable for painting the radiator?
Rust-Oleum 241169 High Heat Ultra Enamel Spray, Black, 12-Ounce https://smile.amazon.com/dp/B001UE7M..._eEdRFb10EXH8T
Old 11-11-2020, 02:42 PM   #2
alexiskai
alexiskai's Avatar
Default Re: Radiator Paint
Pretty sure you can use any paint you want. An unpressurized radiator can never get above ~212° due to the laws of physics. I'd focus more on choosing something that's aesthetically what you want (gloss vs matte) and will adhere to the surface.
Old 11-11-2020, 02:54 PM   #3
oldforder
oldforder's Avatar
Actually, an unpressurized radiator with 50/50 antifreeze in it can get much higher than 212but not that much to worry about.
oldforder is offline   Reply With Quote
Old 11-11-2020, 03:16 PM   #4
alexiskai
alexiskai's Avatar
Good catch, should've said 223°
Old 11-11-2020, 03:27 PM   #5
Fhane
Fhane's Avatar
Use a paint that goes on thin. Maybe Rustoleum Bar-B-Q. The thick enamels will act as insulation and stop the transfer of heat and the engine could over heat.
Fhane is offline   Reply With Quote
Old 11-11-2020, 03:29 PM   #6
Purdy Swoft
Purdy Swoft's Avatar
I avoid heavy paint build up on the radiator . Paint will insulate . I try to just barely cover the radiator with semi gloss black paint . Type or shade of black is a matter of choice , I guess .
Old 11-11-2020, 03:35 PM   #7
Ernie Vitucci
Good afternoon...Were the radiators painted originally...I seem to remember in 1963, my 30 Coupe Radiator did not have any paint on it...perhaps it was a replacement...even in those days...Ernie in Arizona
Old 11-11-2020, 03:43 PM   #8
Paul Mike
Paul Mike's Avatar
Radiator paint is a special paint so that it does not limit heat transfer.
https://www.eastwood.com/ew-radiator...sol-12-oz.html
Paul Mike is offline   Reply With Quote
Old 11-11-2020, 04:09 PM   #9
J Franklin
J Franklin's Avatar
A light coat of lacquer is what I use.
Old 11-11-2020, 04:40 PM   #10
duke36
Our local Home Depot generic flat enamel, $1 / rattle can for the core. Easy to blend and touch up. It doesn't come out thick and not much acetone in it like Rustoleum and the others. Place cardboard on either side of the radiator and/ or mask if core is mounted.
Old 11-11-2020, 09:56 PM   #11
Charlie Stephens
Paul is 100% right on this one, there is a special paint for radiators.
Charlie Stephens
Old 11-11-2020, 10:24 PM   #12
J Franklin
J Franklin's Avatar
Charlie Stephens
If you ca't get that, use lacquer. It is a very thin coat, where enamel leaves a relatively thick coating.
Old 11-12-2020, 11:21 AM   #13
katy
katy's Avatar
Ditto
