Old 07-15-2014, 08:53 PM   #1
gundoca
gundoca's Avatar
Default in need of 38 one ton brake info
Now I'm confused, I thought my 38 one ton had 14" drums but when I I measured the front it comes out 12" and 1.75 width shoes. I have not pulled apart the Timken rear end yet but the drums definitely look bigger. Any thoughts???
gundoca is offline   Reply With Quote
Old 07-15-2014, 09:33 PM   #2
49fordv8f4
49fordv8f4's Avatar
Default Re: in need of 38 one ton brake info
The '42- '47 tonner has 12" brakes on front and 14" on rear. the earlier tonners may be the same.
Mark
49fordv8f4 is offline   Reply With Quote
Old 07-16-2014, 11:21 AM   #3
gundoca
gundoca's Avatar
I think that's the case. So will regularly 12" shoes work up front and does anyone have an idea as to were I could find 14" rear shoes or material.
Old 07-16-2014, 03:27 PM   #4
51504bat
51504bat's Avatar
Any big truck shop should be able to get your shoes relined or direct you to someone who can.
