Old 04-29-2020, 04:03 PM   #1
Jwawhite
Jwawhite's Avatar
Default Rear Bumper Dumpers Heads Up
I disconnected the Dumpers because exhaust was entering through my Tailgate/Upper window Assy.
I was inspecting the bumper "mufflers" Dumpers and noticed the clam shell assembly was leaking on both sides!
Just above the dumper leaks is a cavity from the exterior 1/4 panel and underside of car.
I believe some of the exhaust fumes were entering the cab this route.
The tailgate portion has a minor water leak on left side only.
Jwawhite is offline   Reply With Quote
Old 04-30-2020, 10:08 AM   #2
5851a
Default Re: Rear Bumper Dumpers Heads Up
Ford always exits exhaust to the sides on wagons I believe, up into the eighties anyway. For that reason.
5851a is offline   Reply With Quote
Old 05-02-2020, 10:23 PM   #3
Daves55Sedan
Daves55Sedan's Avatar
I elected not to have tailpipes at all on my '55 Courier wagon. Instead, I turned the exhaust pipe downstream of the cherry bomb and poked it out in front of the rear tire, then put a chrome sleeve over it. Saves on having to use lots of pipe. I am so cheap!
