09-24-2018, 02:37 PM | #1 |
interchanging fuel pump 1946 59-a
My question is, I have 1946 59-AB V8,will the 49-53 pump bolt on? I just need for start up, not a permanent pump. The arm & cup look the same, just not sure.
Thanks for any help, Steve |
09-24-2018, 03:38 PM | #2 |
Re: interchanging fuel pump 1946 59-a
Not sure about the mounting, I know they use different gaskets.
09-24-2018, 07:49 PM | #3 |
No, the 49-53 fuel pump has a different/larger mounting flange than was used on '48 and earlier fuel pumps. Even if the bolt hole center to center is the same, the actuating arm location may not allow the pump to work properly.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 09-24-2018 at 07:54 PM. |
09-24-2018, 10:52 PM | #4 |
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
