09-21-2013, 01:17 PM | #21 |
Re: Best way to cut sheetmetal
all of the above suggestions and tools are good, but there is no way to cut a perfectly straight line by hand, if you need clean straight cuts find a shhet metal shop to cut them, shop around till you fond a shop thats reasonable, if you buy the material from them they will be more willing to work with you on price
09-21-2013, 03:09 PM | #22 |
At work a bench shear arrived, I laughed at it, but have grown to like it --it has about a 12" cut, not too hard to cut a sheet in a straight line --i have seen them for 100$ --this one on enco sometimes has free shipping --http://www.use-enco.com/CGI/INPDFF?PMPAGE=672&PMCTLG=00
I havn't seen the most baisic method --cold chisel and hammer mentioned ---but going the the sheet metal shop is good advice |
09-21-2013, 07:49 PM | #23 | |
Sure wish I had that car back in good condition, like it was before we cut it up into a field buggy. |
09-21-2013, 08:13 PM | #24 |
I'm in the middle of putting new patch panels on the bottoms of a spare pair of CC pickup doors.
The best I've found is to use a 4" grinding wheel in either an air grinder or an electric grinder. You can buy the 4" wheels in 0.035 thin-ness and following a line is not hard. The wheels are available at www.mscdirect.com and are MSC #: 59963223 It leaves a cut virtually distortion free and any imperfections/unstraightness can be removed with a file held perpendicular and longitudinally. Air grinder available at Harbor Freight. The 90 degree version may be easier to use but I don't own one. Don't forget the mandrels. Joe K
Shudda kept the horse. Last edited by Joe K; 09-21-2013 at 08:22 PM. |
09-21-2013, 08:38 PM | #25 |
You say you have a wood band saw.
How much horsepower does it have???? 1/2 or more?? Will it mount standard 16 or 18 tooth metal cutting blade???? An old worn out blade works fine for FRICTION SAWING. Clean the wood dust out of the saw first. Run the saw on it's HIGHEST speed and wear a welding jacket, gloves and a full cover face shield. There's going to be a lot of hot chips flying around. Some will be red hot. Clamp some kind of ripping fence on the saw table. Have at it. Feed as fast as you have horsepower to keep the blade speed up to maximum. As strange as it seems, there is almost no heat spread into the sawed parts. It all goes out in the kerf. Oh, by the way, it's going to be noisy. Wear ear muffs. |
09-21-2013, 08:58 PM | #26 |
09-22-2013, 08:29 AM | #27 |
Cutting a couple strips can be done without buying anything, by using a sharp scribe, a straight edge and your hack saw. If your strips are only a couple inches wide as you mentioned, use the hack saw for the 2 inch side and score the long dimension several times and score the back side also, use some pressure. When you think you have scored it enough take a couple crescent wrenches or vice grips to grab the strip and move it up and down til it cracks off. If it starts to bend near the score edge, you didn't score it deep enough. Take a file to dress the raw edge and you're done. If you don't have a strong scribe, sharpen a nail set to a point, they're harder than sheet steel. Problem solved no tools bought, money spent. Not the best way, but the cheapest.
09-22-2013, 08:38 AM | #28 |
I have heard that a bandsaw can do a nice job on sheet metal if the blade is reversed. That is the teeth are pointing up and running quite fast. I haven't tried it myself.
09-22-2013, 09:10 AM | #29 |
