03-17-2013, 06:26 PM | #21 |
Re: Fuel line ferrule
That would be the cheapest way out ,buy a new line. ken ct
03-17-2013, 06:50 PM | #22 |
Ross, you don't need to modify the taper on the ferrule itself. The sorta' rounded surface is on the nut itself & pushes just on the angled side of the ferrule. Bill W.
03-17-2013, 07:03 PM | #23 |
Dog here, And now, have we completed FERRULES-101?
What mind stimulating subject will we do next? Motor Oils, Timing, Anti Freeze, Gear Oils, Frame Sag, those dreaded FAM's, Alternators, Torque Specs, etc, have ALL been exhausted, along with exact procedures on replacing the Muffler Bearing! Buster T.
03-17-2013, 07:38 PM | #24 | |
03-17-2013, 07:51 PM | #25 |
Same here do NOT modify ferrels,they will work out of the box. ken ct.
03-17-2013, 07:59 PM | #26 |
03-17-2013, 08:33 PM | #27 |
No one mentioned that the tubing must extend beyond the end of the fitting, putting the Ferrule back from the end of the tubing. About a 1/4" or so.
03-17-2013, 08:40 PM | #28 |
When the ferrule snaps off the fitting and fail they are usually junk and are not going to be re usable.
03-17-2013, 10:45 PM | #29 |
Well, Brother Purdy, I'll find out tomorrow. Have a new gas line with "that" kind of fittings. I feel that if they are really "squeezed" down good, that they will be as re-usable as regular ferrules. Maybe they're tougher brass than the usual ferrules & take a little more OOMPAH! & a smear of grease to get them mated to the line well. They're designed to "pop" loose from the fitting when tightened to "squeeze" on the line. Bill W. (Even REAL brothers don't always agree on everything!)
03-17-2013, 10:53 PM | #30 |
I just bought one of those sediment bowls and when I tightened up the nut on the setiment bowl the ferrule got pushed up into the outlet and I had to dig it out of there with a drill bit. I dont think it will seal now.
03-17-2013, 11:12 PM | #31 |
Possibly, these "new fangled" fittings might not pan out & so back to the regular fittings. MAIN thing, through this long thread is that we don't want someone to have a GAS FIRE & destroy their car!! Bill W.
03-18-2013, 01:17 AM | #32 |
I also don't like the attached ferrule. You have to crank on the fitting until just before stripping the carb threads before the ferrule finally breaks off. I fixed a guys carb problem a couple years ago, when his car kept running out of gas. He had the nut only snug and had a bunch of teflon tape wrapped on the ferrule. The teflon tape was plugging the inlet, so I removed it and really cranked on the nut before the ferrule finally broke off and squeezed tight to the fuel line. That fixed his fuel leak and fuel blockage.
03-18-2013, 06:39 AM | #33 |
On the one piece break off ferrules i have been scoring them a little more with a small hacksaw blade so they break off easier when tightened. They seem to be made with a little to much material connecting them at the break point..
03-18-2013, 07:17 AM | #34 | |
Joe K
Shudda kept the horse. |
03-18-2013, 08:56 AM | #35 |
Success thanks to Bill W. I used the normal ferrule that has approx. 20 degree angle on both sides and generously used petroleum jelly on the ferrule and then tightened. I noticed that the ferrule at the carb was the normal 20 degree angle on one end and approx 45 degree angle on the other but since I didn't have that one I used the one that I did have. NO LEAKS. Thanks all and especially Bill W. I'll get the correct when I can find one.
07-11-2023, 03:12 AM | #36 |
I bought a new gas line from the carb to the pump, when I installed it I couldn’t get it to stop leaking at the pump. When I took the line back off, the ferrule at the pump end was lying loose in the pump. I noticed a tiny nick on the ferrule so I got a new ferrule. I can’t get the new ferrule to seat on the line where the line should stick out at the end at least 1/32”. Subsequently I can’t tighten the line enough to get it to not leak, there’s no more threads left to tighten.
Tim Carlig |
07-11-2023, 08:37 AM | #37 | |
07-11-2023, 09:12 AM | #38 |
I know you’re not supposed to do it, but I have been known to smear a light coat of thread sealant on the ferrule and on the threads of the compression nut when assembling. If nothing else it lubricates when you are tightening the nut to swedge the ferrule to the tubing, and helps prevent stripping out the pot metal on the sediment bowl.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
07-11-2023, 09:35 AM | #39 | ||
07-11-2023, 09:54 AM | #40 |
I think those are two separate issues.
