Old 09-29-2021, 10:51 AM   #1
HenryCarl
Default 1935 Coupe spare tire bracket strap
Me again. After finding my spare tire cover, rusted and dimpled more than I was willing to accept, I did this. Notice the bullet hole. I won't fix that.
But, now I can used my lock. Here's a picture. It seems deformed. Any opinions or picture of what it should look like?
Thank you,
Jim
HenryCarl is offline   Reply With Quote
Old 09-29-2021, 11:29 AM   #2
Don Rogers
Don Rogers's Avatar
Default Re: 1935 Coupe spare tire bracket strap
This should help.
Don Rogers is offline   Reply With Quote
Old 09-29-2021, 12:35 PM   #3
HenryCarl
You always do. Thank you. The body bracket's lower lugbolt has a nut that seems welded on. I'm unscrewed that bolt and then putting strap there and passing the bolt through and tightening that nut. Seems like it was made for that.
Old 09-29-2021, 12:49 PM   #4
HenryCarl
While installing strap/ban, I also rotated the wheel so that the air valve is on top, pointed downward.
Old 09-29-2021, 01:04 PM   #5
petehoovie
petehoovie's Avatar
Originally Posted by HenryCarl View Post
Me again. After finding my spare tire cover, rusted and dimpled more than I was willing to accept, I did this. Notice the bullet hole. I won't fix that. But, now I can used my lock. Here's a picture. It seems deformed. Any opinions or picture of what it should look like?
Thank you, Jim
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 09-29-2021, 01:13 PM   #6
DavidG
DavidG's Avatar
With the air valve at the top, the drain hole inside of the hub of the wheel is at the bottom as was the design intent.
Old 09-29-2021, 03:13 PM   #7
HenryCarl
FordBarn is the best place, the best, for solutions. Thank you also for the vent at the bottom info.
Old 09-29-2021, 05:03 PM   #8
mercman from oz
mercman from oz's Avatar
1935 Ford Spare Wheel with Locking Hubcap and Bracket. Notice that the Valve is in the correct position at the top.
Old 09-29-2021, 05:09 PM   #9
mercman from oz
1935 Ford Locking Hubcap and Attached Bracket.
Old 09-29-2021, 08:52 PM   #10
mercman from oz
The owner of this car has mounted his Spare Wheel incorrectly. The Valve should be placed at the Top.
Old 09-30-2021, 02:01 PM   #11
Don Rogers
Don Rogers's Avatar
Trevor for completeness sake, here is the short strap dimension drawing.
Old 09-30-2021, 05:07 PM   #12
mercman from oz
Don, Thanks for the Measurements of this Spare Wheel & Tyre Lock Band.
Old 10-07-2021, 04:51 PM   #13
mercman from oz
1935 Ford Spare Wheel Holder. On the bottom stud, there is a small Flat Nut. The end of the Locking Bracket fits under this Flat Nut which is then tightened. Then you mount the Spare Wheel and Tyre with the three regular Wheel Nuts. Then add the Spare Wheel Cover, then attach the Strap attached to the Locking Hubcap and you are all done. Hope that this helps.
Old 10-11-2021, 04:15 PM   #14
HenryCarl
Complete descriptions. Fully covered. The tire cover is fully installed. And the valve is at the top. Thank you all for the rescue!
Old 10-11-2021, 05:06 PM   #15
mercman from oz
Henry, That is great news. Regards Mercman <><
Thread Tools
Display Modes
