Old 01-09-2019, 05:20 PM   #1
qmdv
qmdv's Avatar
Default 1932 Clutch and brake return springs
I forgot witch is witch. The long one on left is .060 spring wire. The short on on the right is .080 spring wire.
qmdv is offline   Reply With Quote
Old 01-09-2019, 05:23 PM   #2
35fordtn
35fordtn's Avatar
Default Re: 1932 Clutch and brake return springs
The one on the Left is the 7523 Clutch spring, the one on the right is the brake spring.
35fordtn is offline   Reply With Quote
Old 01-10-2019, 04:19 PM   #3
Allinger
It may not be of any help, but I just replaced my brake linings on my 32 Sedan. They are original Ford equipment, so may be different from replacement. I didn't take measurements, but you can make a 'best guess' from the ruler. See pictures.
Allinger is offline   Reply With Quote
Old 01-10-2019, 04:45 PM   #4
qmdv
qmdv's Avatar
I should have specified clutch and brake pedal return spring
