03-08-2014, 06:58 PM | #1 |
Mitchell overdrive spline !!!
Thanks again for the previous advice I have received on Fordbarn.
I am proceeding with the rebuild of my rear end and I am trying to to a thorough job. The double cone bearing race in the Banjo has been replaced also new bearings so the pinion preload must be set.. The car has a Mitchell overdrive and I am wanting to set the pinion preload as per "Tom Endy's Article. The problem I have run into is trying to find the size of the 1/2 inch drive socket that will fit the Mitchel overdrive drive shaft spline. I have a 1/2 inch drive beam torque wrench to do the job. Does anyone know what size socket is required for the Mitchell spline and is it a six or 12 point socket ? Thanks Mark. |
03-08-2014, 07:12 PM | #2 |
Re: Mitchell overdrive spline !!!
A half inch beam torque wrench most likely would be FOOT POUNDS, rather than INCH POUNDS.
For sure you don't want to mix them up. My inch pound torque wrench is 3/8" drive. They also come in 1/4" drive. If you have an inch pound torque wrench in 1/2" drive, it may have such a high reading that it might not be accurate or it might be hard to make out something like 10 inch pounds. |
03-08-2014, 07:17 PM | #3 |
Hi Tom ,
Yes the 1/2 drive beam torque wrench is in foot pounds . Thanks for alerting me to this. I will need to get an inch pound one. Do you know the size of the socket that will fit the Mitchell drive shaft spline ? |
03-08-2014, 07:27 PM | #4 |
I don't know but Tom Endy likely does.
03-08-2014, 07:32 PM | #5 |
Thanks Tom
03-08-2014, 07:50 PM | #6 |
03-08-2014, 07:54 PM | #7 |
Hi Ford1931,
Thanks for the advice. I would never have thought of this as I would have thought that the torque would cause some movement at the joint where the tape is. Did you use PVC electrical tape ? |
03-08-2014, 09:38 PM | #8 |
On a Mitchell stub shaft I put several wraps of duct tape around the spline and wedge a 36mm socket over it. The socket is a 1\2" drive so I have to adapt it down to my 1\4" dial indicator wrench. A 36mm socket is used on the rear axle nut of the old VW Bugs.
Tom Endy |
03-08-2014, 10:33 PM | #9 |
Thanks from me also. I am in the middle of setting the same thing.
03-09-2014, 12:03 PM | #10 |
I used a socket very close to the diameter of the Mitchell shaft and used the green body paint tape to secure it. I think any tape would work because it doesn't take much to hold 20 inch pounds.
