05-06-2023, 07:34 AM | #21 |
Re: New project: 41 ford pickup
you might consider saving the cab you have. If 400. scares you, check out what people expect to get for a good cab..........
05-12-2023, 06:04 PM | #22 |
That cab is staying and getting repaired.
Respecting and Resurrecting Ford Model A's. |
05-12-2023, 06:08 PM | #23 |
Also got the parallel rear springs fitted. Engine/trans mounts fitted as well. The rear axle is a 74 bronco 3:54 nine inch.
05-12-2023, 10:21 PM | #24 | |
05-24-2023, 08:45 PM | #25 |
Driver door had some issues so I found a nice 46/47 to swap out. Only damage was the lower hinge (like most) went past its limit and bent the inside structure and tore out the rivets. This is by no means a concourse truck so I fixed it how I knew I could. It will be finished tomorrow and I will rosette weld the studs and try to make them look like rivet heads.
05-28-2023, 08:53 PM | #26 |
05-28-2023, 09:44 PM | #27 |
05-28-2023, 11:23 PM | #28 |
That is some really nice frame rail work. Not an easy thing to fix for sure. A+ on the repair.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
05-29-2023, 02:49 PM | #29 |
Nice looking repair Vanspeed.
05-29-2023, 08:22 PM | #30 |
Vanspeed
You do nice work sir. Bruce
Works good Lasts long time |
06-22-2023, 07:33 PM | #31 |
Thanks guys. I appreciate that. Tackled the spare tire delete today and also fixed a bunch of old crack/farmer fixes. Now they are sitting out in my patina solution aging to match the truck.
06-22-2023, 07:35 PM | #32 |
Frame is also all repaired and painted. Assembly should start next week.
06-23-2023, 09:48 AM | #33 |
Nice truck !
06-28-2023, 08:47 PM | #34 |
Who knows what instrument cluster was in the truck but it is now back to stock thanks to a friend who donated a section of dash from a donor truck.
06-28-2023, 08:54 PM | #35 | |
06-29-2023, 08:57 AM | #36 |
That’s some great progress.
Keep it up! Wish I could get back to work on mine. |
06-29-2023, 08:50 PM | #37 |
Cant believe how many extra holes were in this firewall.
06-29-2023, 10:11 PM | #38 |
07-05-2023, 11:24 AM | #39 |
we are almost neighbors. I live in East Jordan Mi. and have similar interests. I have a 41 pickup myself.
07-05-2023, 11:51 AM | #40 | |
Thread Tools | |
Display Modes | |
