Old 03-08-2015, 08:43 AM   #1
King ford
King ford's Avatar
Default Cereal # question pu - car
greetings fellow barners..I have a question for you guys that know your fords better than I do ...since cars and pickups used the same chassis in 1935 ( at lest I believe they did) did the engine/ cereal # indicate car or pickup? ..thanks in advance guys!
King ford is offline   Reply With Quote
Old 03-08-2015, 09:27 AM   #2
TJ
TJ's Avatar
Default Re: Cereal # question pu - car
The answer is no
Old 03-09-2015, 11:41 AM   #3
itslow
itslow's Avatar
Only way to know is to find out what the guy stamping the numbers had for breakfast that day. May have been a Wheaties day or it may have been a Rice Krispies day. Unfortunately, since the fella is probably long gone, we'll likely never know...
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
Old 03-09-2015, 04:55 PM   #4
Ralph Moore
Ralph Moore's Avatar
Corn flakes!
Ralph Moore is offline   Reply With Quote
Old 03-09-2015, 05:17 PM   #5
r_reed
r_reed's Avatar
give him a break guys, wrong word, but spelled it right. he also spelled chassis right.
1949 F-1 Flatrod II (flat paint, flat motor)
Keeping one more flathead alive
It smoked, but gave it up 7/26/2013
East Glenville NY
r_reed is offline   Reply With Quote
Old 03-09-2015, 06:04 PM   #6
BILL WZOREK
BILL WZOREK's Avatar
SPELLINGPOLICE are Back >>>>>> YAAAAAAAAAAAAAAAAAAAAK <<<<<<
If there is no " F " in phone
Does that mean you should spell FORD >> PORD << ?????????????????
BILL WZOREK is offline   Reply With Quote
Old 03-09-2015, 06:16 PM   #7
rheltzel
rheltzel's Avatar
For all Ford V8 trivia lovers, I offer the following: while the basic chassis was shared between commercial and passenger cars, the commercial, open car, and station wagon frame rails were made of 10% thicker steel (0.11 vs. 0.10 of an inch).
Now, tell me your life hasn't been enriched by knowing this.
rheltzel is offline   Reply With Quote
Old 03-09-2015, 06:23 PM   #8
BILL WZOREK
NOW WE ARE COOKING WITH GAS
FACTS JUST THE FACTS on this site LOL
Old 03-09-2015, 06:27 PM   #9
Lanny
Lanny's Avatar
Sorry King ford, some of childish members here are just razzzzin you a little.
Hope you can take it in stride, as you will hopefully get some good
advise here, on the info you seek.......
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 03-09-2015, 06:29 PM   #10
Willit Stop
Willit Stop's Avatar
That's incorrect Bill.....it should be Phord. What happened to your command of the English language?
Willit Stop is offline   Reply With Quote
Old 03-09-2015, 06:32 PM   #11
BILL WZOREK
2 SHAY
Old 03-09-2015, 06:49 PM   #12
rheltzel
rheltzel's Avatar
Well, Bill, there's definitely a lot of gas in this thread...
Old 03-10-2015, 09:06 AM   #13
Don Rogers
Don Rogers's Avatar
King ford, To address your original question......The serial number was stamped on the transmission of the motor/transmission assembly as it came off the motor assembly line. The number was then transferred to the chassis frame as the motor was lowered into the frame. There was no distinction as to whether it was lowered into a passenger car frame (48-5005) or a pickup frame (50-5005) So the serial number tells you nothing about the type of vehicle.
Your second question had to do with whether the pickup and passenger frames were the same.......
They were similar but not identical. In 1935 there was one frame for all passenger cars (48-5005). This included open and closed cars as well as station wagons and sedan deliveries. Pickups and panel deliveries used a slightly different frame (50-5005). This frame was the same as the 48-5005 except that the side pillar support brackets were not installed. These brackets were used to support the wider passenger car body. Pickup and Panel Delivery restorers often use the more readily available 48-5005 frame and remove the side brackets.
Don Rogers is offline   Reply With Quote
Old 03-10-2015, 10:08 AM   #14
34pickup
34pickup's Avatar
Phunny stuff hear.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 03-10-2015, 12:15 PM   #15
Mike51Merc
Mike51Merc's Avatar
I learned over time to read foneticly in internetland.
Mike51Merc is offline   Reply With Quote
Old 03-10-2015, 03:20 PM   #16
hop2it
King phord. I thought was charcoal brickets.
Doug
hop2it is offline   Reply With Quote
Old 03-10-2015, 03:45 PM   #17
TagMan
I'm hoping you meant (.110" vs .100" of an inch". .010" inch thick frame would be a little flimsy, even for a Ford !!
TagMan is offline   Reply With Quote
Old 03-10-2015, 04:48 PM   #18
ReggieK
He did not have a zero after the decimal point, you placed the zero there. Please note, what he stated is correct. .110" vs .100"
ReggieK is offline   Reply With Quote
Old 03-10-2015, 04:50 PM   #19
rheltzel
rheltzel's Avatar
Indeed, TagMan, you are correct. You will note that I put a 0 in front of the decimal, as in "0.11", another way of expressing ".110", as in your note, above.
Old 03-10-2015, 05:10 PM   #20
Willit Stop
It looks like we've graduated from spelling to dyslexia (.110,.100,0.11). But we're having fun huh? At least King ford got the answer he was looking for.
