02-27-2018, 07:26 PM | #1 |
tube changing
I just need to confirm that I did this correctly. Had a tube that leaked somewhere-not sure where but it did leak. So I popped the outer wall off the rim, pulled the tube and replaced it with another tube. I did not add any cornstarch for lube between the tube and tire. Then I reinflated, seated the tube and popped the sidewall back on the rim. Then fully inflated the tube/tire. Still is holding air. Like I said, I just want to make sure I did this correctly.
Mike
