Old 03-27-2015, 05:12 PM   #1
King ford
King ford's Avatar
Default 302 head question
greetings fellow barners!...do any of you fellows know what would be involved in swapping a set of 1971 302 heads onto a 1990 302 motor?.."thanks in advance for any info!
King ford is offline   Reply With Quote
Old 03-27-2015, 05:59 PM   #2
JeffB2
JeffB2's Avatar
Default Re: 302 head question
Why? There would be nothing gained from it,in fact just the opposite.
JeffB2 is offline   Reply With Quote
Old 03-27-2015, 06:25 PM   #3
darrell
the rocker arms are different so you would need 71 pushrods.
darrell is offline   Reply With Quote
Old 03-28-2015, 01:55 AM   #4
deucemac
deucemac's Avatar
I'm with Jeff.There is absolutely no benefit in using older heads on that engine. The lest that must be done is upfit the heads to run properly on leaded gas. If you want to upgrade your engine than look for Mustang Gt heads with E7TZ casting numbers. Those will be a much better choice. But, bottom line it is you car and your choice in the end.
deucemac is offline   Reply With Quote
