Old 06-16-2020, 03:33 PM   #1
dpson
dpson's Avatar
Default Model A won't start
I finally got around to starting the Model A last weekend and I'll be danged it wouldn't start. It would crank over, but no fire. What the heck? it was running fine when put away last fall. I was just about to start troubleshooting when I spied the gas gage was reading below zero. My grandkids had been playing in the car last fall, which was fine with me, they're 6 and 4 and one of them must have turned on the gas shutoff valve and over the winter the gas drained from the tank. No real harm done, just a lot of cranking and swearing before I figured out the problem. Put in a couple gallons and it fired right up. Good to go !
dpson is offline   Reply With Quote
Old 06-16-2020, 03:52 PM   #2
Sunnybrook Farm
Sunnybrook Farm's Avatar
Default Re: Model A won't start
They may have done you a favor by letting the old gas out though probably not a safe thing to do.
Sunnybrook Farm is offline   Reply With Quote
Old 06-16-2020, 04:59 PM   #3
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Now fix the leak in your carburetor.
Jacksonlll is offline   Reply With Quote
