Old 01-11-2020, 09:43 PM   #21
[email protected]
Default Re: 5 spd in a 37 pickup with a 4.44 rearend.
Getting ready to install the Merc intake and Rochester 2gc with new electric choke. Wish me luck.
jhljr44@yahoo.com is offline   Reply With Quote
Old 01-11-2020, 11:49 PM   #22
Pete
Pete's Avatar
Check the yoke on the rear end for galling in the cup seats. Every thing can be tight but it will vibrate under load. I had the same vibration problem. A new yoke fixed it.
For your info, there is room in the tail shaft housing for 2 bearings. Really helps prolong yoke life.
You will most likely want to install a short throw shift adapter eventually. They really make shifting a pleasure. You can buy them but it is quite easy to make one.
With a 14 inch stick, the knob moves 4 inches from 1st to 2nd.
