03-18-2015, 03:27 PM | #1 |
Engine id.
Friend was looking for an engine to install in a race car for Owensboro KY speed museum. Seller indicated the engine came from a 1939 mercury. Engine was only to be cleaned and painted for looks and not started. After futher investigation we decided we might see if it will run. Have not found a date code yet.
Pistons are standard Floating bearings(all appear in good shape) Relieved block 81T heads Last edited by Ironrod; 12-12-2016 at 09:30 AM. |
03-18-2015, 03:40 PM | #2 |
Re: Engine id.
Hi all; Looks to have a trapazoid mid-block hole and a round center mid-block hole-39-41 Merc/truck 95 hp block- the good one! Newc
03-18-2015, 03:45 PM | #3 |
Re: Engine id.
I think this is a '41 -42 or even more likely the wartime variant of '42, because it has the boss on bell for drilling third oil hole and is factory relieved. All good stuff!
03-18-2015, 03:47 PM | #4 |
Re: Engine id.
You will not find a date code as there are none. Must be identified as Newc stated by features of the block. It also has the raised intake area 41-42.
03-18-2015, 05:04 PM | #5 |
Re: Engine id.
you are braver than me by hanging that block from the front water jacket bolt holes. That is some pretty thin material in that area.
03-18-2015, 05:22 PM | #6 |
Re: Engine id.
03-18-2015, 06:35 PM | #7 |
Re: Engine id.
Thanks for the replies. B-0-B THANKS FOR THE HEADS UP, will tell the owner. At the time we did not think the engine would be worth saving because it was on a dirt floor garage and only paid salvage price. The engine in the race car is full race flathead, after detuning will be in a 1934 coupe for the street. He may want to rethink this idea after hearing about the engine.
Bob |
03-20-2015, 07:40 PM | #8 |
Re: Engine id.
81T heads would be correct for a 1939 Mercury.
03-22-2015, 12:53 PM | #9 |
Re: Engine id.
Raised intake deck pretty much narrows it down...
03-22-2015, 01:59 PM | #10 |
Re: Engine id.
I couldn't have said it better. Looks too nice just to be a lump in a museum.
The more I learn about new automobiles, the more I value my old ones. |
03-22-2015, 04:40 PM | #11 |
Re: Engine id.
It appears to be a 41/42 Merc or wartime engine - am building one as I write this. If the owner is thinking about just sticking it in a museum and not running it, have him contact me and I'll get him a block for that purpose and buy this engine from him. I'd hate to see it just sit - might as well put it to good flathead use!
Let me know . . . B&S |
03-22-2015, 05:04 PM | #12 |
Re: Engine id.
After all of the comments about the engine, he is now retinking his options. We are cleanig all parts and will attempt to run the engine, then make a decision on installing in a 1934 coupe.
Bob |
03-23-2015, 07:17 AM | #13 |
Re: Engine id.
Always great to hear about somebody getting another one running! Good luck!
04-11-2015, 07:09 PM | #14 |
Re: Engine id.
Update for Bored&Stroked. After cleaning and some TLC the engine fired rigt up and ran very well. It is a survivor.
Bob Last edited by Ironrod; 12-12-2016 at 09:30 AM. |
