02-10-2015, 12:41 PM | #1 |
Air compressor for home shop
I no next to nothing about paint and air comressors. I may want to paint smaller items such as fenders or door panels. I had an old compressor that i found at garage sale. Have done small painting projects with it. It quit on me yesterday. Now looking for advice fo another compressor. I was thinking that the Ingersoll Rand 2HP 4.4 cfm would suffice. Model P1IU-A9 It is contractor grade twin stack and oil lubbed direct drive. Any advise is appreciated. Or recommendations.
Steve Hanna, Polk City, IA |
02-10-2015, 12:54 PM | #2 |
Re: Air compressor for home shop
Not enough CFMs one hit with impact and wait for pressure to build. Good for staple gun
Maybe good for air brushing. IMO 15 CFMs would be smallest I would buy |
02-10-2015, 01:04 PM | #3 | |
Sorry, not to throw aspersions. I have a sears red one - 5 hp (so they claim) and about 5.5 SCFM. DeVillbiss made these for Sears for many years. Also same compressor in the current DeWalt available today at HomeDepot. It will do any impact wrenching I want even using my 750ft-lb "SuperBertha." As for painting using my Binks No. 7 clone - its loafing. Maybe 30 percent duty cycle. It will not sandblast. a 1/8" nozzle such as on my TIP one bagger requires a minimum of 7 SCFM. More is betterer. And nozzles wear quickly to the next size. I would say your IR contractor compressor WILL paint - but you'll have problems with moisture. This a problem with small receiver tanks. You might try running the air through the old compressor tank (assuming you feel it's safe) simply to help remove moisture. Or, if your old compressor isn't more than 20 years, likely you can find parts for it? The Internet is very much a help in these matters. Replacement reed valves for the DeVillbiss/Sears are still around - but NOT at Sears. Check Amazon or even Ebay. Joe K
Shudda kept the horse. |
02-10-2015, 02:22 PM | #4 | |
02-10-2015, 02:26 PM | #5 |
Here is the place I feel has the best deals on compressors;
http://www.aircompressorsdirect.com/ I own an Ingersoll Rand, and the only advice I would give is to see if you can afford to purchase one they say is manufactured in US simply because of the duty cycle. The off-shore units will work however they tend to "overrate" their specifications IMHO. |
02-10-2015, 02:28 PM | #6 | |
A 5 hp single stage will yield a little over 14SCFM. A 5 hp two stage will get you over 17SCFM. I went though this recently when I comparative priced out compressors to replace (and augment) the Sears compressor. I finally settled on Harbor Freight finest ($799 list, but can be bought for $699 on sale sale) which I felt was the better buy for me. Joe K
02-10-2015, 03:27 PM | #7 |
You can find a good compressor buying guide here. You may be shocked to see how much we have to pay for these in Canada....
https://www.kmstools.com/blog/wp-con...uyingGuide.pdf |
02-10-2015, 03:27 PM | #8 | |
02-10-2015, 03:52 PM | #9 |
Agree all.
The compressor does more work in the shop than any one of us. Regardless of what you end up with, for painting you will have moisture, oil vapor, and various other crud in your air that will fish-eye your paint when you get that far. I strongly suggest a good quality filter that will not break the bank....just before your paint gun We use the CamAir QC3. It has a moisture indicator, the cartridges are replaceable, and it removes oil vapor also. It is an entry level rig, but does what it is supposed to do. We can paint about 3 cars before changing the cartridge. We only run paint air thru it, as the air tools do not require filtration like this TCP Global prolly has them
'31 180A |
02-10-2015, 04:00 PM | #10 |
Lotsa good info over on 'The Barns' sister publication, The Garage Journal http://www.garagejournal.com
02-10-2015, 04:13 PM | #11 |
I've been struggling with this for a while. I have a small IR I bought for $65 at an auction. It is a great machine but not big enough for sandblasting large items. I'm limited at 30 amps due to my wire size to my garage.
I've looked at old gas powered tow behind compressors, but the decent ones bring $2500 in our area. I'm scared to buy a non runner because of the rebuild costs if it turns out to be worn out, and really shouldn't pay more than scrap value because of that. It seems for big jobs it's cheaper to have someone else do it or rent the equipment. If anyone comes up with an idea for a source of cheap air pressure I'd really be interested. |
02-10-2015, 04:15 PM | #12 |
I'm still running my 1953 Westinghouse 2 stage 250 psi. not sure of the cfm.
My Dad had it in our repair garage. I have had it since 1972, have run it a lot. It is leaking a little at the valves, but still works fine. I did have to replace the motor some years back. |
02-10-2015, 04:15 PM | #13 |
NEVER< NEVER< NEVER buy a direct drive OILLESS air compressor. They are a short life, throw away, noisey piece of crap. If someone gave me a brand new one I would set it by the curb for the junk man to haul away.
I've worn out a few twin cylinder single stage Sears compressors. They are 20 to 30 gallon tanks, and OK for airing up tires and very light sand blasting. The best money you can spend is to buy the best compressor you can afford. A 5 to 7.5 H.P. belt drive twin cylinder, two stage, 60 to 80 gallon tank, is what I should have bought many years ago. This is especially true if you do sandblasting. |
02-10-2015, 04:39 PM | #14 |
I have two of these
http://www.homedepot.com/p/Husky-60-...602H/205389936
02-10-2015, 04:43 PM | #15 |
Hi Tom,
I'd be careful with announcing placing brand new Sears compressors out by your front curb ........... you might have more Model A's passing in front of your house than you would ever think is possible. |
02-10-2015, 05:19 PM | #16 | |
Meet Mr. Gordon and Mr. Smith's contribution to the hobby. Not mine. I had my pix as avatar for a while. Will blow up to about a 1/4" nozzle (about 40SCFM) Your neighbors will LOVE you after the first 8 hours of blasting. Joe K
02-10-2015, 05:40 PM | #17 |
CFM. is what it's all about. A spray gun will take 12 CFM and a sand blaster will take 25 CFM. Get a good two stage that will do the job and you won't be sorry. Most people I work with have these little compressors and all you do is wait for it to get up to pressure instead of working.
The Old Tinbasher |
02-10-2015, 10:18 PM | #18 |
I appreciate all the comments. I think i need to emphasize that i do not have an active shop. I perhaps will never paint car. Maybe something small no bigger than a door panel size or metal trunk like a Kerri Keen trunk. I care not if takes longer to do. I simply cannot justify paying for comercial quality price. Is there a a compressor that could be used as I've indicated that could be purchased for not more than about 500.00 or am I just delusional. I normally use compressor for basic shop tasks such as solvent parts cleaning, tires, small air powered impact tools, etc. Just would like to be able to paint with my inexpensive wagner gravity feed sprayer if need arises. You think iIcan find something?
02-10-2015, 10:24 PM | #19 |
I'm using an older Wards two cylinder single stage 110 volt 2 H.P. compressor that I bought on Craigslist for $40. It's actually a very good compressor and I can sandblast steady at 40 lbs. pressure. It's not really made for non stop use, so I give it a rest between blasting parts. I've found some real bargains on Craigslist.
02-10-2015, 11:00 PM | #20 |
Thx Tom. That is encouraging. Need something that is not pro but can do it by giving it time to recover. I'm not in a rush. I'm happily retired. Would like to find something adequate but not much more so I can afford it.
Thread Tools | |
Display Modes | |
