08-06-2014, 09:18 AM | #1 |
What modern tire do I use on my 1938 rim
What size radial do I use on my 1938 DeLuxe rim?
08-06-2014, 09:34 AM | #2 |
Re: What modern tire do I use on my 1938 rim
600x16
08-06-2014, 10:26 AM | #3 |
You could use p195/70/R16, blackwall. That is what I have on my 39. Charles
08-06-2014, 11:36 AM | #4 | |
Most of the modern radial tires, P195, 205, 215 are built to go on a 5" wide, or wider rim.. Putting this size of tire on a narrow rim will cause the tire bead to be pulled in, which will put additional pressure on the rim and also cause the center of the tire tread to not run properly on the road. One of the most valuable lessons I have learned is; "Don't let the direction on the can outsmart you"... If the direction say; Mount on 5-7" wheel, that means they should not be used on wheels narrower than that..
Bill.... 36 5 win cpe |
08-06-2014, 09:43 PM | #5 |
08-07-2014, 11:42 AM | #6 |
According to the "Coker Tire Catalog", the P215/70R16 tire, that "38 coupe" has on his '37 Ford, is intended to be mounted on a 5.5-7.5" rim, the overall diameter is 27'6". A 600x16 is generally a 28" tire, the P215 would alter the gear ratio; lower, which will increase engine RPM's, a concern for hiway driving... I have radials on every car I own, have been using them since the late '60's.. After driving a vehicle with radial tires, it is near impossible to go back to bias ply tires...
08-07-2014, 01:48 PM | #7 |
08-07-2014, 05:00 PM | #8 |
08-08-2014, 08:58 PM | #9 |
Thanks a bunch guys. Bye the way. I just made my own coil conversion from the bottom half of an old coil. Now I use a 6volt standard tube coil and does it work great. After buying 2 new coils and trying 2 old coils to no avail, this really works great.
