Old 04-08-2021, 10:34 AM   #1
jstrez5
Default spark plug wires
changing my spark plug wires on a 39 flathead motor the wires going to the 2 caps on the distributor are they marked to show where each wire goes or what would be the best way to exchange the wires i don't want to mix them up i purchased the original colored coded old style wires . THANK YOU JIM S.
jstrez5 is offline   Reply With Quote
Old 04-08-2021, 11:00 AM   #2
CSPIDY
CSPIDY's Avatar
Default Re: spark plug wires
match them up and replace one at a time
CSPIDY is offline   Reply With Quote
Old 04-08-2021, 11:21 AM   #3
Kube
Kube's Avatar
It would be very difficult to change these wires one at a time.
I'd suggest you mark the internal distributor terminal(s) before removing the wires. Personally, I'd engrave the respective number next to the terminal 'socket".
Also, I'd strongly suggest you check continuity of each wire before reinstalling the conduit, etc. That's a simple way to be certain you placed the wires in the correct "socket" and all of them remained seated during assembly.
Old 04-08-2021, 01:23 PM   #4
Zeke3
Zeke3's Avatar
I agree with Kube, do them all at once. The 12116 terminal plates for the helmet distributor, that I have seen, have two sets of cylinder numbers by each of the wire cavities, so you just have to know how the cylinders are numbered and which side you are working on to get them in the correct location.
Zeke3 is offline   Reply With Quote
Old 04-08-2021, 02:45 PM   #5
rockfla
rockfla's Avatar
As the experts above have posted, I find doing them all at once is easiest. I also find that IF you work yourself backwards from the plate, then orient the wires through the cap opening with the two shortest to the outside of the tube opening (if you will) and the two longest to the inside of the tube opening (if you will), then slide the rubber boot on, then feed them into the tube it goes fairly smooth that way (for me anyway).
rockfla is online now   Reply With Quote
Old 04-08-2021, 06:32 PM   #6
drolston
drolston's Avatar
Take the time to solder the bare center wire to the crimp-on clip that goes over the end of the wire at the distributor end. That way, if you have to pull out one from the distributor cap, you know the end clip will come out with the wire. Unless you need originals for show points, you might consider using Raga connectors at the spark plug ends. They can be put on easily after the wires are fed through the wire looms. They screw together to make a reliable connection.
Old 04-10-2021, 08:16 AM   #7
Robert/Texas
Robert/Texas's Avatar
If you decide to replace one wire at a time, I suggest spraying silicon lubricant into both ends of the wire looms. I just had to replace two wires in my '34 roadster, and this made it easy for me.
Robert/Texas is offline   Reply With Quote
Old 04-10-2021, 08:42 AM   #8
Kube
Kube's Avatar
Okay, please explain why you would only replace two wires? Did you cut them by mistake or otherwise damage them?
Old 04-10-2021, 09:07 AM   #9
Terry,OH
Terry,OH's Avatar
Original inner caps are marked with the cylinder numbers 1-4 on the R, 5-8 on the L
Old 04-10-2021, 10:20 AM   #10
Robert/Texas
Kube.
In 1996 I replaced the original style sparkplug wires with the “modern” type with molded ends. This year two of these wires failed, the metal press-on connections burned out. As a temporary fix I reinstalled two of the old wires. I plan to replace all the wires with new original style ones when I can find a set of knurled nuts that fit Champion D21 sparkplugs. I tried those from my Model A’s and T’s but neither have the correct threads. Note that these cars also have Champion spark plugs. I hope that someone can lead me to finding these.
Thanks, Robert
Old 04-10-2021, 11:55 AM   #11
Kube
Kube's Avatar
Kube.
In 1996 I replaced the original style sparkplug wires with the “modern” type with molded ends. This year two of these wires failed, the metal press-on connections burned out. As a temporary fix I reinstalled two of the old wires. I plan to replace all the wires with new original style ones when I can find a set of knurled nuts that fit Champion D11 sparkplugs. I tried those from my Model A’s and T’s but neither have the correct threads. Note that these cars also have Champion spark plugs. I hope that someone can lead me to finding these.
Thanks, Robert
Robert, Get in touch with Mike Driskell. He sells the nuts in two different thread pitches (sizes). Perhaps he'd be able to help.
Old 04-10-2021, 12:13 PM   #12
Robert/Texas
Thanks Kube, Ill call him next week. He's not open today.
Old 04-12-2021, 03:54 PM   #13
Robert/Texas
Thanks again Kube. He's sending me both types of nuts today. I also ordered new wires from him.
Robert
Old 04-12-2021, 03:59 PM   #14
Kube
Kube's Avatar
Robert
Wonderful~!
Old 04-16-2021, 01:52 AM   #15
cajunfirehawk
cajunfirehawk's Avatar
Thumbs up Re: spark plug wires
I found the dive helmet setup on my flatty one of the most complicated plug wire swaps ever but as someone posted silicone lube is your friend, did all of mine at the same time.
Regards,
Todd
1936 FORD Tudor Slantback
"cajunhotrodder" on instagram/youtube
cajunfirehawk is offline   Reply With Quote
