01-04-2021, 01:05 PM | #1 |
68C and A400
Happy New year. a friend of mine had some top header panel extensions that go on the top irons to seal. he had them cast in bronze, he made up some extra sets. now it is time to have them plated. we are talking about having them water plated rather then chrome or nickle. just checking what is you ford barner`s thoughts
01-04-2021, 03:01 PM | #2 |
Re: 68C and A400
Not sure how that will hold up to the elements??
You're talking about the process used to woodgrain I believe?? Paul in CT |
01-04-2021, 04:05 PM | #3 |
Re: 68C and A400
They will be rubbing on the rubber seal which is like a find sandpaper.
Originally they were pot metal held on by squishing metal posts and the whole unit was plated together. Pretty sure they should be only Nickel plate, but it has been a while I would have to double check. So the chrome like paints that area available today would not match well what a proper plating would be. I have some machined stainless set up for screw on the back side that I bought from the one 68C parts guy in PA. He was the one that wore the hat with a headlamp bucket and made stainless parts. |
01-04-2021, 04:21 PM | #4 |
Re: 68C and A400
I make them out of aluminum and polish. Small screws mount them from the backside
Originals were plated pot metal. I don’t really know what water plating is.....maybe I live under a rock! |
01-04-2021, 07:38 PM | #5 |
Re: 68C and A400
the last ones i has were made of stainless. very costly, but very nice. the water type plating is really pretty nice. them parts are really not exposed to the elements most of the time. and being made out of bronze they should hold up.
01-06-2021, 08:31 AM | #6 |
Re: 68C and A400
Is the part identical between the 68C and the 400A ? |
01-06-2021, 12:00 PM | #7 |
Re: 68C and A400
Is it the piece that goes here ?
01-06-2021, 09:30 PM | #8 |
Re: 68C and A400
thanks guys you answered my question. these parts are only on the 68C and A400 here is a couple pictures. they are not on the 68A or B. I will be taking some to my plater
01-07-2021, 05:10 AM | #9 |
Re: 68C and A400
Hmm... I guess it must be this one..
01-07-2021, 05:21 AM | #10 |
Re: 68C and A400
Guess it must be the continuation of this raised section..
01-08-2021, 09:16 AM | #11 |
Re: 68C and A400
Hydroplating at one time was used quite extensively in the custom motocycle/chopper industry when those things were hot. I have seen wheel rims, gas tanks, fenders, helmets, pretty much anything that will fit in the tank. Its really a cool process. I would imagine it would hold up to the elements but like a lot of things I havent seen the results a few years down the road. But, I dont think it would cost too much to nickle plate those small parts. May as well do it right the first time around.
01-08-2021, 10:27 AM | #12 |
Re: 68C and A400
Since it's been awhile, I guess I have to go out in the 30 degrees to see what I have or don't have. How about taking pics with light behind the camera as the object is dark and shadowed.
