Old 06-10-2015, 07:13 AM   #1
hangarb7
Default looking for zenith carb diagram
Greetings,
It has been diagnosed at a tour meet this past Saturday that I have a piece of dirt in my Zenith 1 carb. Car would only start and run with hand throttle advanced and he pulled out the idle jet and the turned off the GAV and nothing happened, car continued to run. Right before this, actually half way to the meet, no problems.
They suggested I take off the carb and blow it out, but now that I have it off and I separated the halves, not sure where to blow the air. I did find a clean carb for the most part with a bit of grit on the bottom of the bowl that I cleaned out.
I see a full cutaway diagram on line for the model B carb but cannot find a flow diagram for the Zenith 1.
Any suggestions?
Thanks,
JackD
hangarb7 is offline   Reply With Quote
Old 06-10-2015, 07:27 AM   #2
Rex_A_Lott
Default Re: looking for zenith carb diagram
I dont have a diagram for you, but now that you have it apart, just blow through every orifice you can find, in both directions. Give it a shot of carb cleaner too.
Good Luck
Rex_A_Lott is offline   Reply With Quote
Old 06-10-2015, 07:31 AM   #3
Sparky
Sparky's Avatar
Check this out:
http://modelabasics.com/carb%20basics%202.htm
Sparky is offline   Reply With Quote
Old 06-10-2015, 08:49 AM   #4
JD 1931
JD 1931's Avatar
modela.org is the site for model a carbs......
JD 1931 is offline   Reply With Quote
Old 06-10-2015, 10:02 AM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
AND a lots of other GREAT info! Paul has done a MARVELOUS job, setting up this website.
I CAN'T imagine the amount of TIME & TALENT it took to do this AND, if you E-Mail him, he WILL answer you.
It's a good place to take the "mystery" out of HOW things work & helps you be able to diagnose a problem, when one occurs. You CAN'T correct a problem, UNTIL you know WHAT needs FIXIN'
Strangely enough, WIKIPEDIA is also a good source for auto related stuff.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 06-10-2015, 12:27 PM   #6
Mitch//pa
Good Luck
Agree carb cleaner with a straw and then blow through every hole you see also the orfices on the brass parts.
Old 06-10-2015, 01:38 PM   #7
hangarb7
GREAT! Thanks for all the advice, and SPARKY, that is exactly what I was looking for. Thanks. I googled this before I posted and this never came up.
Have a great day guys.
JackD
Old 06-10-2015, 06:04 PM   #8
Terry, NJ
Terry, NJ's Avatar
Thank you , Sparky! These diagrams were just what I needed Too!
Terry
Terry, NJ is offline   Reply With Quote
