05-06-2023, 01:33 PM | #1 |
adj tappets 40 block
Starting to do the valves and the lifters adj screw is so tight i just broke a orig johnson tappet holder on the first one,anyone having had the same problem ? Did a motor years ago with with real johnson lifters and these same holders and there was no problem at all. Now that the holder is broken i cannot try any other of the tappets, not going to take the motor apart to drill holes in it.
thanks kurt not to happy |
05-06-2023, 01:39 PM | #2 |
Re: adj tappets 40 block
Plus i just did a valve job on my 40 coupe and the lifters adjusted fine , that motor was built in the 80's.
05-06-2023, 04:32 PM | #3 |
I always drill the tapped holes prior to building the engine, then all you have to do is stick a nail in the hole to lock the lifter. Never could get the original Johnson holders to work without slipping out.
05-06-2023, 05:04 PM | #4 |
i put 2 wrapped in leather in a vice and barley could move them would be a real mess with a jammed nail in the block.
05-06-2023, 09:19 PM | #5 |
I prefer them to be tight as possible - it keeps the lifters from losing their adjustment. I drill the lifter bores with a 3/16 hole. I put a metal punch into the hole to hold the lifter. I also tend to adjust them to the approximate length by holding them in a vice before installation and setting the length to what it should be (at least close) - then I fine-tune in the engine.
05-07-2023, 09:29 AM | #6 |
thanks kurt |
05-07-2023, 08:59 PM | #7 |
If the bottoms are soft (and I've heard that some of the repops are like that, then they should go back). The bottoms should be heat-treated and hard. If you have a set of used lifters - send them to Pete1, have him resurface them. That would be the best situation.
05-12-2023, 04:57 PM | #8 |
You are S O L if you purchased the lifters off the internet from that engine builder in Fresno CA. They are beyond TIGHT!. He says no one else has a problem. B S. He will take them back but he charged $56.00 shipping. You don't get that back. I sent one set back and I had extra Johnson bolts for the other set. Shipping should have been about $15.00 USPS flat rate box. When he first started selling them he said he found them [ hollow Johnsons ] in a warehouse. Ya sure he did.
05-12-2023, 05:23 PM | #9 |
I purchased a used but low mileage 274 C I D flathead. Valve lash was all over the place. No holes in the lifters bosses. What am I to do. Made this tool. Smooth end of a drill for the pins. Nice and hard. Turn the engine over to get the valve up. Back down. Check lash. Repeat until you have it right. I don't need this tool for my engines because I have the FASTEST system around for adjusting valves. This tool won't be strong enough for Fresno lifters. Throw them away. What's this stupid URL http///to send a picture??? Please inform.
05-12-2023, 05:52 PM | #10 |
Ordered a set of new REAL johnsons $495 shipped, what the hell at 73 i'm not taking anything with me.
thanks kurt |
05-13-2023, 11:54 AM | #11 |
Regarding adjustable lifters, this thread may help. I posted a modified Johnson tool and also made a couple of pin wrenches to do the job
https://www.fordbarn.com/forum/showt...nson&showall=1 Glenn |
05-14-2023, 08:26 AM | #12 |
I posted a picture of my pin wrench on the HAMB because I don't know how this freakn' URL works on here.
05-14-2023, 10:15 AM | #13 | |
https://www.fordbarn.com/forum/showp...&postcount=649 |
05-15-2023, 05:52 AM | #14 | |
https://www.jegs.com/i/Isky-Racing-C...F8502/10002/-1 Here is an eBay add: https://www.ebay.com/itm/32563896720...7526%7Ciid%3A1 |
05-15-2023, 10:11 AM | #15 |
I talked to schnieders and was told that their ford flathead lifters are not china but were not USA made, I would think that ISKY may be the same, didn't want to take that chance.still anything can go bad.
05-15-2023, 10:34 AM | #16 |
i see now that ISKY is USA made ,didn't know that when i ordered the johnson lifters, maybe next time.
05-15-2023, 11:36 AM | #17 |
Are those Isky's adjustable?
