07-22-2020, 08:41 PM | #1 |
U Joint
Picked up a good used U JOINT AT SNYDERS TODAY MY QUESION IS SHOULD I Pack it with greese or just greese it with greese gun after everything is put back together
07-22-2020, 09:07 PM | #2 |
Re: U Joint
I just finished putting my spare motor/trans in my car and I packed the u-joint/clam shell the best I could before bolting it together, then I used the grease gun to complete the job.
When the grease started coming out the speedo gear housing on the drive shaft tube I was happy. I'm not sure if that is the correct way but I know my u-joint is packed full of grease. I used JD Corn Head Grease |
07-23-2020, 06:39 AM | #3 | |
Re: U Joint
Enjoy. |
07-23-2020, 08:27 AM | #4 |
Re: U Joint
Might change out the grease fitting with a modern Zerk type to simplify pumping in grease with a gun. The fitting just threads in and is an easy change.
07-23-2020, 09:52 AM | #5 |
Re: U Joint
Bob Bidonde |
