Old 07-05-2019, 02:46 PM   #1
dono50
dono50's Avatar
Send a message via MSN to dono50
Arrow 50 Ford 8ba spark plug fouling problem
Installed H10c spark plugs a few years ago and have a fouling problem.
Need recommendations regarding best plugs to use for 50 flathead that is used on a limited basis.
Thanks
dono50 is offline   Reply With Quote
Old 07-05-2019, 03:25 PM   #2
supereal
supereal's Avatar
Default Re: 50 Ford 8ba spark plug fouling problem
I use Champion RJ14YC spark plugs. They have a long snout that resists fouling. I know that many consider Champion to be undesirable, but I have used them for decades. I set the gap at .028. If the fouling is fluffy black, that usually indicates an over rich fuel condition. H-10 plugs have a long history of fouling.
supereal is offline   Reply With Quote
Old 07-05-2019, 03:47 PM   #3
flatheadmurre
flatheadmurre's Avatar
If the engine has some mileage and you don´t drive it hard i would go one number hotter plug...
Old 07-05-2019, 10:27 PM   #4
dono50
dono50's Avatar
Thanks, I will take you advise
Old 07-06-2019, 06:43 AM   #5
Pat/Ohio
Pat/Ohio's Avatar
I have had good results using the Autolite 216 spark plugs in my '50. Pat
Pat/Ohio is offline   Reply With Quote
Old 07-06-2019, 06:58 AM   #6
Gene1949
Gene1949's Avatar
Plugs don't foul because of limited usage. There is an underlying problem (fuel, ignition issues/timing, oil consumption).
Another easily correctable cause is starting the car for 2 minutes to "circulate the fluids".
Gene1949 is offline   Reply With Quote
Old 07-06-2019, 07:15 AM   #7
tubman
tubman's Avatar
Check any new Autolite plugs when you buy them. There is a thread on the H.A.M.B. about the manufacturing now being done "offshore" and the quality has gone to hell.
Old 07-06-2019, 07:38 AM   #8
oldford2
oldford2's Avatar
I have been using Champion H12's for many years and engines.
oldford2 is offline   Reply With Quote
Old 07-06-2019, 07:52 AM   #9
OhioRick
OhioRick's Avatar
Let’s get to the root cause of your problem. Even a perfect plug will foul when your running too rich, has improper timing, poor spark, bad rings or improperly seated valves.
Let’s see a picture of one of these fouled plugs??
OhioRick is offline   Reply With Quote
Old 07-06-2019, 08:13 AM   #10
flatford8
flatford8's Avatar
I use Autolite 216 in a stock ‘50 and have had two where the electrode pulled right out of the plug. I agree with the other posters that think you have another problem to cause fouling. Plugs won’t foul from lack of use...... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 07-06-2019, 08:54 AM   #11
joe 1950
joe 1950's Avatar
i agree with these boys you’ve got something else going on there lve used champ. H 10 in my 50 since i’ve owned it 22 years my friend has a 40 cpe. 35 pk. up. also uses champ. no problems how many of them are fouling ck compression is the ignition system strong and i hate to say it again but don’t forget maybe sticky valves ad some mmo to the fuel best medicine the old girl can get
joe 1950 is offline   Reply With Quote
Old 07-06-2019, 01:09 PM   #12
supereal
supereal's Avatar
If you are experiencing plug fouling, resist placing MMO or any other additive to your fuel tank or crankcase. Performance improvement is very rarely obtained from a bottle or can.
Old 07-07-2019, 12:03 PM   #13
Ggmac
I just had a similar situation. Limited use , fuel evaporates but the MMO doesn't . Drove to the show smoking a bit , filled the tank , smoking was gone . Then I remembered adding 8 oz of MMO to 1/4 tank and I forgot to fill up last time .
Ggmac is offline   Reply With Quote
