04-07-2017, 03:06 PM | #1 |
Early Zenith Idle Jet # 10??
I'm restoring an early Zenith double venture carburetor for my carb collection. I mostly have focused on the aftermarket carbs for the Model A made in Russia, Japan, Argentina, etc. Plus, a goodly number made in the US. This carb, the double venture Zenith, is a bit unusual so I'm trying to restore one to original for the collection. I only need the idle jet # 10. That is the one Steve Pargeter specifies for this carb.
I'd appreciate your help so please look through your carb stuff and let me know if you have the #10 idle jet. I have a number of other Zenith/Holly carb parts to trade or I can strait purchase. Again, thanks for your help! Jim Gregory [email protected] |
04-09-2017, 03:11 PM | #2 |
Re: Early Zenith Idle Jet # 10??
A # 10 jet is 0.5 mm diameter, the #11 0.55mm dia ( you can do the math, I am sure, for 1/1000s of an inch, or google can!). The small 2035 cc engine that Ford Uk produced alongside the 3.3litre had a #10 jet as standard. If the carb is an early one without the brass well in the secondary chamber the original jet would have been slightly longer than the later ones ( these had to be made shorter to fit in the well). I have run a#11 jet in a 2035cc engine successfully...I've probably got a #10 in the shed but I don't know if it's stamped and it is almost certainly the later length which was about 2mm ( about 1/10 inch) shorter and anyway hardly worth shipping costs! Interesting though.
04-09-2017, 06:06 PM | #3 |
From Rex Reheis Carburetor book
04-09-2017, 07:44 PM | #4 |
In addition to the #10 Idle jet, the very early Zenith used a #18 (.o36)Compensating jet, forged steel throttle and choke levers, the choke lever did not have a bottom leg. As said before there was no removable secondary well .
A later #11 Idle jet (.021) will work just fine if you want to use the carb for driving. Other features of the very early Zenith is a boss and pin on the back side of the lower housing for retaining the double ventuti, no boss and pin on the front side and a raised "Z" on the engine side of the upper housing, no "Z" on the front side. I believe the forged steel levers are the most difficult to locate, when assembled a #11 idle jet cannot even be seen unless you open up the carb. Just my opinion. Ron |
04-10-2017, 05:06 PM | #5 |
1. How are the 20 degree throttle plates marked?
1a. I was told that they were unmarked ... problem is most of the Repros are also unmarked! 2. Or is the 20 degree plate an urban myth? 3. Will an 18 1/2 degree plate work in the early upper casting? Thanks Last edited by Benson; 04-10-2017 at 06:47 PM. |
04-11-2017, 02:00 AM | #6 |
2) Don't know 3) Yes |
04-11-2017, 08:36 AM | #7 |
From my memory, the 20 deg. plates have no markings. The 18 1/2 deg plates were marked that way so that people would know that they are different from the early 20 deg plates.
