04-26-2016, 12:10 AM | #1 |
keeping tires
i just bought 4 brand new tires and i wont be using them for quite some time.
besides keeping them tucked in a corner somewhere, what is the best way to keep them from dryrotting, cracking or whatever. would spraying them with a tire conditioner every so often help ? thanks |
04-26-2016, 12:13 AM | #2 |
Re: keeping tires
I'd lay them flat and away from sun light.
04-26-2016, 12:17 AM | #3 |
Re: keeping tires
Cool dry place out of sun.
1929 Model AA - Need long splash aprons! |
04-26-2016, 12:48 AM | #4 |
Re: keeping tires
If you also have new inner tubes, I'd stick them inside the tires and inflate them just enough to take shape. If you leave them flat or folded they will likely crack.
04-26-2016, 01:27 AM | #5 |
Re: keeping tires
Curious, why did you buy them if you won't use them for a long time ? Wayne
04-26-2016, 05:46 AM | #6 |
Re: keeping tires
ODFever 1930 Ford Model A Town Sedan "Alyssa" |
04-26-2016, 07:30 AM | #7 |
Re: keeping tires
If white walls, do not let the white side touch the Blackwall ... That is when stacking tires on top of each other or leaning against each other.
Says so right on the tire wrapping of some new tires. Last edited by Benson; 04-26-2016 at 08:01 AM. Reason: additional info |
04-26-2016, 08:15 AM | #8 |
Re: keeping tires
As others have recommended; lay flat, off the ground, away from sun light and keep them far, far away from electric motors or electirc welding (anything that generates ozone). Wrap or cover them with plastic and face them whitewall to whitewall.
I would be reluctant to put any type of tire dressing on them as some chemicals will actually leach away the rubber preservative in the tire.
I Love Anything That Turns Money Into Noise |
04-26-2016, 08:40 AM | #9 | |
Re: keeping tires
04-26-2016, 09:13 AM | #10 |
Re: keeping tires
curious as to what- "quite some time is"?
If a couple of years, I'ld sell them and buy a set when I was ready. |
04-26-2016, 09:22 AM | #11 | |
Re: keeping tires
04-26-2016, 01:07 PM | #12 |
Re: keeping tires
04-27-2016, 06:47 AM | #13 |
Re: keeping tires
Why are you buying tires way ahead of time?
04-27-2016, 07:01 AM | #14 |
Re: keeping tires
If you have a basement, use it!
04-27-2016, 07:36 PM | #15 |
Re: keeping tires
a great deal at a swap meet
05-03-2016, 10:24 AM | #16 |
Registered User
Re: keeping tires
if they are over 10 years old ,or dont have a date code the tire places will refuse to mount or repair them
05-03-2016, 10:43 AM | #17 |
Re: keeping tires
05-03-2016, 11:19 AM | #18 |
Re: keeping tires
05-03-2016, 02:39 PM | #19 |
Re: keeping tires
Mot good point,what is the date code,might not have been a good deal!
05-03-2016, 03:44 PM | #20 |
Re: keeping tires
I won a set of new tires about 4 years ago. Did not need to replace my current tires at the time. I Bought some large vacuum bags and used vacuum cleaner to vacuum the air out. They sealed up tight and I kept them on an overhead shelf out of the light. 4 years later, the seals were still intact and the tires were as freah as new.
Steve Hanna, Polk City, IA |
