04-12-2016, 08:41 PM | #1 |
removing drive shaft
tell me how to remove the drive shaft from the banjo rear ?
it appears that it has a threaded hub securing the driveshaft gear to the banjo housing ? thanks for the advice |
04-12-2016, 09:15 PM | #2 |
Re: removing drive shaft
Tom Endy has very good article on rear ends. I think now look for Santa Anna's model a club web site.
04-12-2016, 09:25 PM | #3 |
Go to santaanitaas.org Click in the black bar at top three bars, scroll down to technical reference and look in Tom's articles. Hope this help you!!
04-12-2016, 10:02 PM | #4 |
The "threaded hub" you are looking at is (I'm Guessing) is the Pinion Gear Bearing Adjustment nuts and threads. They hold the pre-load adjustment on the Pinion Bearings. The Pinion Gear is held on the drive Shaft by a nut on the end of the Drive Shaft. The Pinion Gear, Pinion Bearing and Drive Shaft, as a assembly, are pulled out of the Banjo Housing by a puller. The puller is available from some of the parts vendors.
Yes, Tom Endy's write-up is an excellent source of information to do this job.
I noticed the harder I work the luckier I get! |
04-12-2016, 10:16 PM | #5 |
Go to the web site of the Santa Anita A's of Arcadia, California at www.santaanitaas.org. On the home page put your cursor on "Technical Reference", my name will appear below, click on it. A menu of technical articles will come . Several such as differential repair, Mitchel overdrive installation, and drive shaft removal should help you. You are gong to need a drive shaft puller. You can get one from the Mitchell overdrive company. Tom Endy |
