12-20-2015, 10:00 PM | #1 |
model a front bumper
the model A frame,has a front curved frame piece.
can that curved area be cut off ? i want to perch the frame from the front spring ? can it be done ? |
12-20-2015, 10:05 PM | #2 |
Re: model a front bumper
Explain "perch the frame."
Good enough.. Isn't. |
12-21-2015, 12:30 AM | #3 |
perch
to lower the frame below the spring to attach a "perched" bracket, the short end to the top of the spring, the other longer end attached to the front of the crossbar on the front of the frame. picture an upside down L bracket ( brace ) |
12-21-2015, 12:37 AM | #4 |
What is your final goal as the fenders also attach to the curved horns?
12-21-2015, 12:52 AM | #5 |
You would probably get a much better answer to your question on HAMB: http://www.jalopyjournal.com/forum/
Charlie Stephens |
12-21-2015, 03:20 AM | #6 |
12-21-2015, 04:40 AM | #7 |
Maybe you can attach a drawing! Wayne
12-21-2015, 09:26 AM | #8 |
I agree, I have no idea what 1917modelT is referring to. It kind of sounds like he is trying to modify the frame (or some attachments to the frame) to make a hotrod.
Rusty Nelson |
12-21-2015, 12:26 PM | #9 |
I think he is building what they call a suicide front end.
Bob Last edited by Bob C; 12-21-2015 at 12:55 PM. |
12-21-2015, 02:55 PM | #10 |
I've NEVER known of anyone getting killed from one. Most are built with GREAT strength & INTEGRITY. They've been used for MANY YEARS. The building of them has become quite an ART FORM.
Bill W.
12-22-2015, 04:12 PM | #11 |
actually iam building a rat rod with both a front suicide and a rear suicide setup
my thought is to hang the rear frame, thru a perch, attached to the top of the rear spring. and supported thru side rails of course. i would appreciate any thoughts on this setup |
12-22-2015, 04:15 PM | #12 |
and this will be a fenderless hotrod
and i intend to cut off those curved front pieces and perch that end from the spring. |
12-23-2015, 03:07 PM | #13 |
Even the HAMB would give him a hard time with a rat rod.
