Old 04-22-2020, 10:37 PM   #1
Steve Plucker
Default Starter switch parts???
I have these two parts which are the same.
They are made of fiber and the area where the 3/8" hole is measures 3/4 x 3/4, then it shoots up at a 90 degree angle for 1/4 inch.
I believe it goes within the early square starter, the 3/8 inch hole acceoting the battery cable bolt...but just where in the assembly I have no idea unless it is situated near the metal casing.
Anyone?
Thanks.
Pluck
Photo to come soon.
Old 04-22-2020, 11:24 PM   #2
Dan Partain
Dan Partain's Avatar
Default Re: Starter switch parts???
Here's the photo for Pluck.
Dan Partain is offline   Reply With Quote
Old 04-23-2020, 06:03 AM   #3
chrs1961815
chrs1961815's Avatar
I have seen these on the regular starter switches as well. I wish somebody would reproduce them, but you could make them yourself. At any rate I think a lot of people don't have them in their switches as nothing seems to happen.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 04-23-2020, 01:07 PM   #4
d.j. moordigian
d.j. moordigian's Avatar
Here you go Pluck...you remember this?....lol
https://www.fordbarn.com/forum/showt...starter+switch
d.j. moordigian is offline   Reply With Quote
Old 04-23-2020, 02:23 PM   #5
Steve Plucker
Hell, I can't remember what I did yesterday let alone 9 years ago!
OK...I have just three of those and three square starter switches...SO they must belong to the early type switch.
I think I figured it out as to where they go in the assembly of things.
They go on the inside just before you slide the battery cable bolt through the casing...it is the only place I can see as to where it goes.
Pluck
