Old 02-24-2020, 12:36 AM   #1
Daddysearly30pickup
Default Correct wiper motor for 82-A pickup
Hello,
Vacuum or electric, which is correct wiper motor and where are they available?
Thank you
Daddysearly30pickup is offline   Reply With Quote
Old 02-24-2020, 01:11 AM   #2
Dan Partain
Dan Partain's Avatar
Default Re: Correct wiper motor for 82-A pickup
The 82-A came with a manual wiper. There should be a tube in the top of your windshield for the wiper assembly to pass through.
Dan Partain is offline   Reply With Quote
Old 02-24-2020, 11:36 AM   #3
ryanheacox
ryanheacox's Avatar
Lightbulb Re: Correct wiper motor for 82-A pickup
Take a look at your right hand. That’s your motor
Old 02-24-2020, 12:03 PM   #4
Bob C
Here is a picture of the tube and wiper.
Bob
Old 02-24-2020, 12:58 PM   #5
Joe K
Joe K's Avatar
For a while JC Whitney sold an electric powered wiper done in the usual "universal" style. 6 volts, and the wiper was notable in having a threaded shaft which the wiper shaft passed through.
One took off the keeper nuts, passed the threaded shaft through the 82A hole, and then used the hex nut on the outside to keep the wiper motor from turning. The base of the motor had a low durometer rubber "seat" which kind of conforms to whatever the motor is seated against and this aids in keeping the motor from turning.
Here is today's equivalent which is conveniently available on ebay at https://www.ebay.com/itm/FORD-VINTAG...9/282961853843
He says more than 10 available.
Joe K
Shudda kept the horse.
Old 02-24-2020, 03:16 PM   #6
J Franklin
J Franklin's Avatar
he was wanting a correct one.
Old 02-24-2020, 08:17 PM   #7
rotorwrench
rotorwrench's Avatar
As far as powered units are concerned, it could be electric or vacuum since Ford eventually went pretty much to vacuum operated in 1930 for cars that came with them as standard. If a person wants to add one to a pickup then stuff is available to do that. If you don't drive it in the rain, the standard hand control model would be fine.
