12-24-2014, 06:05 PM | #1 |
Wheel alignment
I don't mind a little side to side wobble but I don't like the up and down.
How much is acceptable? I am going to have an overdrive so I want as little as possible but how much is too much? Has anyone tried to straighten? |
12-24-2014, 07:21 PM | #2 |
Re: Wheel alignment
Any wobble is to much. Up and down? Your front end should be tight no looseness
Check all joints! Wishbone ball,king pins,tie rod ends,steering balls,pitman arm wheel bearings,etc. |
12-24-2014, 07:30 PM | #3 |
Re: Wheel alignment
Up and down?? I would assume you mean the wheel are out of round??
Paul in CT |
12-24-2014, 11:30 PM | #4 |
Re: Wheel alignment
Wheel with no tire on it. Spin the wheel and you have up and down runout or you have side to side runout or both. The up and down will make a true tire bounce. Side to side, I don't think is as critical.
Now, how much is too much? |
12-24-2014, 11:36 PM | #5 |
Re: Wheel alignment
I would want 1/8" or less for either measurement.
12-25-2014, 11:07 AM | #6 |
Re: Wheel alignment
Glen
'31 Model A Deluxe Roadster '31 Chrysler Model 70 Sedan '88 Pontiac Fiero GT '36 Auburn Boattail Speedster replica |
